Event Coverage Aluminum flathead crusing across america to pleasanton..pics and coverage..
Discussion in 'The Hokey Ass Message Board' started by gooseta2, Aug 19, 2010.
  1. havi
    havi
    Wow, my pants are tight!
  2. bonesy
    bonesy
    That's about the coolest mill I've ever seen!
  3. moefuzz
    moefuzz
    .... We Need More Pics!
    .......... We Need More Info!
    UpDaTeS ????
  4. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    holy cow!
    holy ****!
    i want one! $12k aint that terrible for a brand new motor. I bet you could soak that much into an old one.
  5. Fe26
    Fe26
    Very well done gent's, a superb effort.
    x2 on what Dynaflash_8 said
  6. 58Lincoln
    58Lincoln
    Great job guys!
    Tremendous amount knowledge, skill and work involved.
    Looking forward to checking it out at Pleasanton.
  7. flatheadpete
    flatheadpete
    from Burton, MI
    Sunuva!! Look at the size of those headers!! Looks damn good.
  8. THR1LL3R
    THR1LL3R
    from St. Louis
  9. Zerk
    Zerk
    I can already see that engine in a '49-'51 coupe. No, sedan. NO, COUPE! Not lowered, mild dechroming, rolling on widened 15" steels with baby moons with no trim rings.
    Like a Korean War era musclecar. Hunting Hondas.
  10. A Chopped Coupe
    A Chopped Coupe
    REALLY FANTASTIC!!!!!!!!!!
    I along with hundereds of people have been waiting a v......e......r......y long time to hear this. You mentioned he was coming to California with the car/motor............if so, when and where, I'd like to see it and talk about it.
    As for the guys that say the price is HIGH..............anyone who has built a flat motor to make 250HP or more.......................how much did you spend? The $12k for a long block looks to certainly be in the ball park.
    Great Job!!!!!!!
  11. CRFyou
    CRFyou
    is there info yet on the performance?
    i would sell a motorcycle or two to afford this engine if you're over 250 horse.
    details please!
  12. brigrat
    brigrat
    from Wa.St.
    Maybe you would like to test it out in a '36 Ford roadster next year!
  13. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    Like everyone else........DETAILED specs please!!
    Awesome what you have done there......simply awesome.
  14. lowkroozer
    lowkroozer
    All of the above ,,,,,,,,,,fabulous job men
  15. Wild Turkey
    Wild Turkey
    Will it accept any heads/manifolds from "real" flatheads? I've got a 4x2 Weiand that would look sooooo good on one!
  16. RAY With
    RAY With
    Very impressive looking flatty. When is production expected to be available to us old flatty nuts? I as well as every one else would be interested in the dyno results and any additional information you can give us at this time as to the internals.
  17. gooseta2
    gooseta2
    It is going down to Roush Racing when they get back...and it's going on the Dyno....I'm trying to get all the info and spec's to the HAMB first to keep you guys informed...it will accept aftermarket intakes..it has a 3.5 in bore by a 4 and 4 3/8 in stroke....making it a 339 cu. inch....it has a **** crank....and an oil s****er built into the girdle designed oil pan...it has a screw on SBC oil filter or you can use a old school remote style.....Roller Lifters amd a roller cam custom cut buy ISKY....All new redesigned water pumps that are high volume...Mark said the Engine did not go over 180 degrees on the tri(even in hot weather idling....It mostly ran between 150 degrees and 180 degrees...it has a one piece timing cover that accepts SBC oil seals...and is avalible in spider and post type....rear seal is a SBC rear seal...I beam style connecting rods....and wensco pistons....
    The ports in the new MCF block are a result of numerous flow tests. The problem of factory removable valve guide was resolved by resorting to a pressed in guide of a smaller diameter. This increases the cross sectional area of the port in a critical spot. The new port is d-shaped to further increase the cross sectional area and allow for a better shape leading to the short side radius. The valve size is increased to 1.7” diameter and it uses a smaller stem (7mm vs 11/32”). The smaller stem takes up less area in the port and eliminates some weight from the valvetrain. any more question just message me and I'll try to get you the answers... <o:p></o:p>
    <!--[if !supportEmptyParas]--> <!--[endif]--><o:p></o:p>
    Goose
  18. dudley32
    dudley32
    Goodness Gracious...is that a flathead...:D
  19. bobscogin
    bobscogin
    How about some photos of the internals?
    Bob
  20. grovedawg
    grovedawg
    from Heber, UT
    Just one more motor I'd LOVE to have! Add this one to the list!
  21. rodderbilly
    rodderbilly
    from italy
    any news about the new flathead?
  22. thecockeyedwallaby
    thecockeyedwallaby
    from Kelowna
    Question... will there be a list of what is and isn't interchangable from the original parts?
  23. troylee
    troylee
    This may be a goofy question but does it still sound like a flatty? Nice lookin mill also.
  24. hasty
    hasty
    It looks fantastic. How much weight does it save over the original?
    Looking forward to full specs - I was searching for details a couple of weeks ago. Things seemed to have gone quiet. Glad to hear it is still moving.
  25. hasty
    hasty
    You mention the range of heads it will take - Do you have a picture of the effect each has on performance?
  26. RAY With
    RAY With
    Nay sayers??? Bad mouth?? What the hell is there not to like about an all aluminum Flatty? The numbers so far are good and the ideas are appearing to be working right on schedule and no doubt will be a demand item for several years to come. One of those in my Roadster would look absolutely awesome. Good luck on the final streach!
  27. hasty
    hasty
    Looking forward to the numbers. Will you post them on this thread?
  28. Here's a pic of the 34 Ford that the motor is in.This was taken several years ago when I lettered the doors.
  29. daddio211
    daddio211
    So WHEN exactly will the blocks be available for purchase???
  30. rodderbilly
    rodderbilly
    from italy
    news about the price?others?
