Technical aluminum heads
Discussion in 'Traditional Hot Rods' started by Prawbly, Nov 16, 2015.
  1. Prawbly
    Prawbly
    Other than looking great, is there any advantage to aluminum finned head over stock cast iron head ?
    If not what is the best cast iron head to use ? thanks Pat
  2. gimpyshotrods
    gimpyshotrods
    Higher compression ratio. Better heat dissapation.
  3. PontiacPower67
    PontiacPower67
    Weight reduction... It's not always one thing that can eliminate 40lbs, but 40 things that can eliminate 1 pound at a time.
    And...
    Typically you can run a higher compression ratio with aluminum heads.
  4. uncle buck
    uncle buck
    The best cast iron head for you to use would be the one that fits whatever you are working on.....
  5. Gene Boul
    Gene Boul
    Generally speaking the cast iron head makes more power. Won't look as cool or remove the weight but power with a cast head not a problem.
  6. unkledaddy
    unkledaddy
  7. Atwater Mike
    Atwater Mike
    I recalled the older guys back in '53, '54 saying "If you can't afford 'High Compression heads' (finned aluminum) then get 59AB heads..."The hot setup"!
    Later years learned some, the earlier heads have varied combustion chamber configurations, think there were 3 variations, 59AB being the least desirable. (low compression)
    As for 'best performance', Barney Navarro did extensive research, (one chapter in his book was dedicated to the flathead head...he named mfrs., and barred no secrets.
    I'd use Navarro heads, remanufactured now, but pricey.
  8. revkev6
    revkev6
    from ma
    what book??
  9. cadillacoffin
    cadillacoffin
  10. Compression ratio is pretty much meaningless. What you want is chamber efficiency. It has been proven (JWL's dyno testing) that 45-50 thou clearance over the pistons provides the most squelch efficiency and thus the most hp/torque increase, at the same time giving the best fuel economy. The shape of the combustion chamber will have a small part to play, but not huge. My C7RA-A iron heads on my C59A have been milled to give 45thou clearance, and they give 155lbs compression with WOT, yet run cool. In fact I had to install thermostats to get the engine up to efficient operating temperature.
  11. init1
    init1
    Hard to beat cast iron. Be sure they are not cracked and have not been shaved too many times. Pretty much bullet proof and they don't corrode like aluminum.
  12. rusty rocket
    rusty rocket
    I like the look of the finned heads on my T modified. IMG_0126.JPG IMG_0129.JPG Unless you are racing and know how to do the super tune on the motor I bet you would never detect the differents between aluminum and cast iron.
  13. 2935ford
    2935ford
    I'm running 221 cast iron heads on my 59a............works good for me!
