Hot Rods aluminum painted wheels ?? how ?
Discussion in 'The Hokey Ass Message Board' started by putz, Sep 24, 2022.
Tags:
  1. putz
    putz
    from wisc.
    any one have any tips on painting alum . wheels with sucess that withstands mother nature ??
  2. Stu D Baker
    Stu D Baker
    from Illinois
    Lightly sandblast the surface to be painted. Spray a couple coats of zinc chromate primer and refinish with your favorite paint. That's it in a nutshell. Your paint supplier can give you more specific information relating to the brand paints that you will be using. Wear proper respirator and safety equipment. Good luck.
    Algoma56 and alanp561 like this.
  3. oldiron 440
    oldiron 440
    I agree with sandblasting but I would sand the aluminum with 180 grit paper after sandblasting then spay epoxy primer followed with paint of your choice.
    rod1 likes this.
  4. fastcar1953
    fastcar1953
    powder coat ?
    alanp561 likes this.
  5. Had a set we painted last summer. The powder coat was peeling. Blasted off the powder coat, sanded with 180 then epoxied.
    Base/clear the following day
  6. Mike VV
    Mike VV
    from SoCal
    Clean "well" and paint ! Has suited me well.
    These wheels are aluminum. I searched for a paint color that somewhat resembled oxidized magnesium. I found a close color in a primer. I cleaned the wheels with brake clean, and painted them.
    I haven't touched them in any touchup in six years since I painted them.
    Mike
    LOST ANGEL and Algoma56 like this.
  7. b4 after.jpg Living here in rust belt, corrosion of wheels under the clear coat is common. What's worked for me is stripping the wheels, scuffing with red scotchbrite, cleaning, then spray bomb self-etching primer. Spray the color then and it holds for some time.
    X-cpe, Desoto291Hemi and Bob Lowry like this.
