Aluminum power glide
Discussion in 'The Hokey Ass Message Board' started by 63wickedduce, Mar 12, 2012.
  1. 63wickedduce
    63wickedduce
    from atwater mn
    Anyone know what there going for these days
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    $150 at most swap meets.
  3. 63wickedduce
    63wickedduce
    from atwater mn
    Is that just core or c
  4. 63wickedduce
    63wickedduce
    from atwater mn
  5. 26 roadster
    26 roadster
    they go for $150 here also, any "unknown" transmission should be gone through to prevent a lot of work
  6. Hnstray
    Hnstray
    from Quincy, IL
    I have seen them for $75 to $150..........but just bought one, less converter, at a swap meet for $40. Case was clean, no damage evident, guy said he didn't need it and didn't want it setting around. I got lucky I guess, though I don't have an immediate need for it either........so who got the better end of that deal? :)
    Ray
  7. I can get them for 50-100 dollars here. As far as I am concerned all swapmeet trannies are cores. If I open it up and it is good then I am plesently surprised. ;)
  8. hubcap
    hubcap
    from phx
    What he said.
  9. 3wLarry
    3wLarry
    from Owasso, Ok
    always had a soft spot for 'glides...learned to drive in my dad's '64 Impala with a 283/glide...great trannies...they get a bad rap for no good reason...they have a distinctive pump whine that I think is cool.
    kidcampbell71 likes this.
  10. They make good dragster trannies. Nothing wrong with one as far as I can tell. You don't have as many gears but really how many do you need.
  11. I got $30 s**** price for mine.
  12. squirrel
    It's been a long long time since I could give one away...so I sold the ones that I had for s**** a little while ago.
    Like everything else, I'm sure they'll be worth their weight in gold one day...
  13. Mr48chev
    What ever the going core price is for one would be the right price for one in unknown condition. A quick search didn't show anyone with rebuilt powerglides and a core price but probably 50/75 bucks is fair for one that isn't broken on the outside.
  14. mikef813
    mikef813
    To bad your so far away!
  15. 63wickedduce
    63wickedduce
    from atwater mn
    thanks for the help
  16. 327Eric
    327Eric
    whatever you are willing to pay. The only one interested in any of mine have been the recycle yards.
  17. bobss396
    bobss396
    I have a '68 vintage one that I'm sitting on for future considerations. It worked fine when it was pulled, nice fluid, etc. I see them go locally for around $100. Which is a decent price for a whole one. Expect to rebuild one that you get, which is not that bad and parts are available.
    Bob
  18. Stock Racer
    Stock Racer
    1.82 first gear core is worth about $50. 1.76 first gear core is worth about $150. The 1.76 is much stronger for drag racing with sticky tires. The 1.82 is fine for street duty. Identification can be made by removing (just pulls out) and measuring the input shaft. 1.76 shaft is 12 7/8" and the 1.82 is 12 5/8" long.
  19. 63wickedduce
    63wickedduce
    from atwater mn
    Thanks for the info
  20. 3wLarry
    3wLarry
    from Owasso, Ok
    So how do you tell if the trans is still in the car? Are there certain body styles that had the 1.76 first gear? Was the 1.82 gear for lighter cars like Novas or such?...or is it the year the trans was made?
    !962-64 PG's were 25 5/16" long and 1965-later PG's were 28 5/16" long....the reason I ask is that a neighbor has a 1965 Impala Station Wagon with a 283/PG I can get for beans...
  21. Hnstray
    Hnstray
    from Quincy, IL
    Thanks for the info. After reading your post I was curious so i pulled the shaft on my 'new acquisition' and it is 12 5/8 - 1.82. The ****** is from a Nova 6 with the case holes for the air cooled converter.
    Ray
  22. I'd take one for a hundred bucks if I could find one around Austin...
  23. snaptwo
    snaptwo
    If you are thinking street use a quality rebuilt stocker is fine. If you are thinking race, then get ready to spend some long green for a hydraulically operated two speed planetary race box with internal trans brake.Aftermarket case, tool steel input shaft, hard output and we haven't even talked about a stall convertor yet.
  24. 3wLarry
    3wLarry
    from Owasso, Ok
    I bought my wife an off-topic all original 1967 Camaro RS with a 327/275hp/Powerglide, and it ran great and pulled hard when I asked it too...good little trans.
  25. Stock Racer
    Stock Racer
    No way to tell for sure while it's in the car. I've been told that the stronger 1.76 gear was a V-8 trans and the 1.82 was a 6 or 4 cylinder box but I've pulled plenty of 1.82's from V-8 cars. The 1.76 was definetly used in what they felt was a H.D. application. I know of no case numbering system that would tell you. That 65 wagon would be a good candidate for the 1.76 and they are getting harder to find. Stay away from the shorter 62-64, they are course spline output.
  26. Stock Racer
    Stock Racer
    Those air cooled units do not have provisions for cooling lines. I would prefer one with cooling lines even for street duty.
  27. Stock Racer
    Stock Racer
    I have used the stock case and 1.76 ge****t with the stock output in situations up to 800 H.P. I would use the aftermarket input shaft in anything in excess of 500 H.P. or anything with a transbrake.
    There are stock inputs that are better than others. Look for the ones that have a completely shiny machined finish over the black finish ones. They are harder.
  28. mike hohnstein
    mike hohnstein
    from wisconsin
    Some guys will tell you the black shaft is stouter but I never bothered to rockwell either, the real deal is to use a turbo spline shaft of the correct length and bushed turbine turbo hydro converter. It's common to bush the stator support and use a regular turbo converter that isn't turbine bushed, either way is fine, most problems arised due to mismatch of shaft length. 1.82 was in 6 cyl and 283, 1.76 was the 327/409 planetary. Contemperary racing ate up most of the remaining glide inventory and has resulted in every part of the aluminum Powerglide being reproduced by the aftermarket. Complications can rear their head in mixing up rear pump models with later '67 and up units. We've built some pretty impressive units over the years for Camaros with 7,000 rpm automatic upshifts, minimal internal mods, but it's a good plan to employ a steel clutch hub. Always desired a Rat motor Vette coupe w/ a glide, but never found one I could afford.
  29. sunbeam
    sunbeam
    Got one out of a 63 pickup in the corner of my shed I'd give somebody.
