Technical Aluminum radiator mods
Discussion in 'The Hokey Ass Message Board' started by raven, May 7, 2020.
  1. raven
    raven
    Anybody out there have a line on someone who can modify an aluminum radiator and then pressure check it?
    I’m in the Midwest but will ship if I need to.
    t
  2. 1934coupe
    1934coupe
    Modify the tanks or the core? Is it an epoxied together radiator or a fully welded radiator? I've had TIG welders modify mine and it works fine. You need to explain more.
    Pat
  3. raven
    raven
    It’s mods to the tanks and it tig welded together.
    r
  4. raven
    raven
    I need to have the lower hose outlet swapped to the other side and have a clearance ‘cove’ cut into the top tank to clear the fan.
    r
  5. TRENDZ
    TRENDZ
    Need pics of the radiator to give a precise answer, but ***uming it is not an epoxied core radiator, I can do what you need.
    Im in Milwaukee, WI 53228
  6. 1934coupe
    1934coupe
    There you go an answer in a few posts. That's the good thing about a welded aluminum radiator you can move the outlets and change the tank if needed.
    Pat
  7. raven
    raven
    I need the upper tank to clear the fan as you can see in the picture.
    And move the lower hose bib to the drivers side.
    r
  8. raven
    raven
    How do I see if it’s and epoxy core?
  9. raven
    raven
  10. goldmountain
    goldmountain
    Look at where the radiator tubes enter the header panel. If it looks like there is yellow epoxy there, it is an epoxy core. Yours look OK.
    1934coupe likes this.
  11. raven
    raven
    No yellow stuff there.
    r
  12. Tim
    Tim
    from KCMO
    Would think anyone who’s comfortable tig welding aluminum could do it? But if you want it tested etc when your done I’d give Orr radiator service in kck a try
    brEad likes this.
  13. As long as it hasn't had Anti-Freeze in it, it is just a fabrication/aluminum T.I.G. job.
    I lowered the outlet on this radiator, plugged the inlet and outlet filled it with water and used a hand held radiator pressure tester.
    My cousin ran it all last year in his oval track car with no issues
    upload_2020-5-9_7-2-34.png upload_2020-5-9_7-4-10.png upload_2020-5-9_7-5-9.png upload_2020-5-9_7-8-23.png upload_2020-5-9_7-10-51.png upload_2020-5-9_7-13-45.png
    Tim likes this.
  14. thunderbirdesq
    thunderbirdesq
    Anyone with some experience welding aluminum could do that, you can pressure test it yourself with a cheap hand pump, a hose fitting, and expandable core plugs
  15. TRENDZ
    TRENDZ
    If the clearance needed is at least 1/4” away from the tubes, I could do it for you.
    Figure $100, plus the shipping.
    henry29 and dana barlow like this.
  16. raven
    raven
    PM sent.
    t
