Technical Aluminum steering link? Safe?
Discussion in 'Traditional Hot Rods' started by RocktimusPryme, Feb 8, 2020.
  1. RocktimusPryme
    RocktimusPryme
    Now that my cross steer is all mocked up, I measured for my steering link/drag link and am ready to buy.
    Speedway has a pretty good sale going on and has been my go to for the g***er build. They have the drag link in steel the length I need. But they dont have the steering link in my length. They will cut to fit, but its like triple the price. I had intended to go with steel because it seemed the right thing to do. But they offer a bunch of swedged aluminum tie rod tubes. They are 1.125 as opposed to .875 OD of the steel. Im ***uming since they have more options in aluminum than they do in steel that its probably common practice?
    Is aluminum safe for steering linkage in a street/strip car? Should I save the weight and buy the tie rod tube out of aluminum too? Or should I give up the sale and find a steel tube from somewhere other than Speedway? Googling this mostly leads me to threads about rock crawling, so that doesnt cross over much.
  2. The tie rod tubes on my car (the Galaxie in my avatar) are aluminum. They are a larger diameter than the original steel of course, but 50, 000 miles of normal driving with a couple of fairly aggressive evasive maneuvers, no signs of trouble.
    Besides they are anodized a nice gold color and sure do look pretty. :D
  3. 325w
    325w
    I'd not put it in my steering linkage. Bound to be an alternitive
    But that's just my opinion.
  4. I would buy the next size too long (in steel), cut it to the length you need, then run a tap in the end.
    pitman, chromelady and olscrounger like this.
  5. krgdowdall
    krgdowdall
    from Alberta
    If you get a longer one and shorten it , make sure you cut the right hand thread. Left hand taps are harder to find and more expensive. Try Welder Series for tie rods and drag links. ( welderseries.com ) Quick service and usually in stock.
  6. DDDenny
    Is your life not worth the difference?
  7. wuga
    wuga
    I was going to recommend Welder Series as well. Have them in my cars made to size.
    Warren
  8. RocktimusPryme
    RocktimusPryme
    probably not if I’m honest.
    In all seriousness though, I can probably go elsewhere and get them in the length I need. I don’t HAVE to buy from speedway. It’s just convenient.
    But I wanted to know if I’m overthinking it. I mean hey, it’s a race car. If aluminum in extra thickness is just fine, I would like to save the front end weight. Thus the question.
    so far I’ve gotten some alternate options, which I appreciate to be sure. But I’m still hopeing someone comes in with a more scientific go or no go answer. I might look to see if QA1 takes phone calls on the weekend.
  9. chromelady
    chromelady
    I agree with DDDenny, spend the extra bucks and do it in STEEL. YOU NEVER, NEVER, EVER! CHEAP OUT ON STEERING OR BRAKES . DENNIS ( CHROME LADY )
    olscrounger likes this.
  10. jetnow1
    jetnow1
    from CT
    Ok if you do not put that high a value on your life, please put a high value on others, including mine!
    chromelady likes this.
  11. RocktimusPryme
    RocktimusPryme
    It was a joke, relax. Im yet to see a real world argument save for the one guy who says he has had aluminum ones for years with no issue.
    I had it in my head that steel was going to be better, but Im not certain that a 1.125 aluminum tube isnt superior to a .875 steel tube.
  12. LM14
    LM14
    from Iowa
    The aluminum is intended for race cars. I have put them thru hell many times and they are tougher than people think they would be. I would recommend using the straight tubes, not the swedged, though. The swedge tube will break right at the end of the threads every time. Some of the steel tubes are pretty thin and tend to flex a lot, the thicker aluminum tubes won't flex as much. I usually step up to the direct tap tubing with the thicker wall section.
    SPark
  13. RocktimusPryme
    RocktimusPryme
    Thats kinda what I was thinking too with the steel ones. Where do you source yours from? Are those tubes, tubular throughout or are they solid in the middle with only the outside being drilled/tapped?
  14. 13below0
    13below0
    from Erie PA
    We use all aluminum steering and 4 link bars for some off topic off road stuff. 7075 is amazing stuff, it beats the hell out of breaking or bending stuff beyond repair. Wide open design will make whatever you need. There are plenty of other companies that can do it also. I wouldn't hesitate to run alum tube.
  15. RocktimusPryme
    RocktimusPryme
    Yeah, in my googling I have seen that too, that most of the good aluminum stuff is 7075 instead of 6061. I think I might opt for that. Speedway does have my Tie Rod in a 1.13 4130 Chromoly. So maybe Ill buy that and look for my steering link elsewhere in either the better aluminum of a chromoly.
  16. lostone
    lostone
    from kansas
    People only look at things like tie rod linkage from 1 mindset, that's driving it down the street.
    Hardly anyone thinks about the worst case scenario like the engineers who design oem stuff do, that's accidents.
    Tie rods and other linkage are designed out of materials meant to bend without breaking. This is to give the driver some kind of control without losing all steering control.
    Aluminum has a tendency to break when bent to some extremes where steel will still be together.
    I looked at aluminum rods but working in the collision side of the auto field I always look at things from that side.
    Yeah yeah I know.... How often does it happen.. It won't happen to you... Etc etc... I have a shop full of wrecked cars and owners who thought the same thing...
    pitman likes this.
  17. pitman
    pitman
    One consideration, is fatigue life.
    In steel, matl. properties include an Endurance Limit. Stay below that stress level, and far less likely to fail. Steering gear undergoes peak, and fatigue loads, these consort to break things.
    Al, does not, in my 'corroded' memory,
    offer an endurance limit value. This implies (to me), that after enough fatigue loading, it may come undone. The above is loosely, eng. matl. speak interpreted.
    Matl. engineer could help in choosing right stuff.
  18. oldolds
    oldolds
    You guys saying Aluminum is no good better not look under a car made in this century. Most control arms are made of aluminum. Spindles too! If I have any on the s**** pile I will take a picture of how much they can bend without breaking.
    RocktimusPryme likes this.
  19. willys36
    willys36
    I bought a set of left and right-hand taps years ago and make all my own tie rods and drag links using standard aftermarket rod ends. Also bought the proper tapered reamer. They came in really handy in making the Mysterion clone. I use with ½” schedule 40 pipe, perfect for left and right hand 11/16” NF tread taps.
    Making tapered weld-in bungs. 1/2" x 0.16 wall pipe.
  20. kursplat
    kursplat
    i don't know, so i'm asking. OEMs use aluminum for control arms, are none of them using it for any steering parts?
  21. RocktimusPryme
    RocktimusPryme
    FWIW. I know I have to replace the heim joints every so often. The links are that expensive. Unless you do step up and buy custom 7075 stuff. I don’t mind replacing every now and then with the joints.
    Again, there are a ton of these aluminum rods for sale. If they were getting people killed I feel like they would have been sued into oblivion by now.
