Always been a hot rodder...
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by volksmike, Jan 11, 2013.
  1. volksmike
    volksmike
    Hello,
    The Name's Mike. Been a hot rod wanna be since I was about 7. My then Step-father had a '65 vette that was very nicely done. It had some early '70s custom touches. He also had a hot chevy truck. He did garage style paint and body at the house. Along with van murals (it was the mid '70s after all) and other custom paint work. I got my taste of modifying cars from him. After modifying several hundred model cars, I built my first hot rod... It was a Vw squareback wagon 'cause thats what I had at the time. I put a 351W engine midship behind the front seats... That was a fun car...took alot of engineering to get it all to work.
    I have been steadly practicing body working and metal repairs (mostly on Vw's because they rust and I'm decent at it) looking for the right "real" hot rod project.
    I have subscriptions to rod & custom, cl***ic street trucks, etc... Always on the sidelines looking.... One day I'll get one...
  2. mikeallcars
    mikeallcars
    Welcome from west TN
  3. Rodders
    Rodders
  4. Ghost of ElMirage
    Ghost of ElMirage
    glad you're on board!
  5. volksmike
    volksmike
    I'm going to check out a '59 Rambler 6 Wagon tomorrow. I figure I will have to make a lot of the parts for it as there doesn't seem to be much available in the usual outlets. I can't wait to see if I'm gonna bring it home...
  6. donh97
    donh97
    Howdy, welcome. I have a VW Bus, about 63 w/ ***le looking to trade for about a 49 Dodge Step Van or sell. VW has rust & needs engine work, but pretty complete. Even has factory jack. Call or email if interested, donh97@gmail.com 830-739-4364
  7. farna
    farna
    Mike, there aren't many parts in the "usual channels" for the Rambler, but there are some AMC/Rambler specific vendors. Most popular one is Galvin's Rambler Parts in northern California (Lodi -- www.ramblerparts.com). There are a few others as well.
    I see you're in Charleston -- we may have to hook up one day! I'm between Aiken and Columbia (Batesburg-Leesville), a couple hours away. There is a Carolina AMC Club that welcomes custom Ramblers. We have a guy with a 68 Amb***ador with a Chevy V-8 in it. He gets ribbed a little, but all in fun!
    The only thing to remember about that Rambler 6 is it has a torque tube drive. So almost any engine change will require engine/trans/rear axle replacement and mean building a rear suspension. Ladder bars or a four link aren't too hard, and you can retain the stock coil springs -- just take the spring seats off the original axle and bolt to the replacement. Late model Ranger axles are about the right width, Explorer might be a bit wide with the Rambler wheels, may have to get a bit deeper than standard custom wheels.
  8. volksmike
    volksmike
    Well Guys, the Rambler didn't work out. I'm too tall to get in and out without bashing my head on the door pillar. I was looking at a 1963 Falcon as well and THAT one turned out to be a winner. It has some brake issues and the cowl floor is rusted out around the vent tubes. But it does run and is a stick car.
  9. farna
    farna
    The cowl can be fixed, fibergl*** is your friend there! May have to pull the dash. The longer door on the two door Falcon (I'm ***uming it's a two door!) helps a lot with the door post issue.
  10. raymay
    raymay
    Welcome from New York.
