Hot Rods Am I old fashioned?
Discussion in 'The Hokey Ass Message Board' started by Road Kill PU, Feb 1, 2022.
  1. One thing that I notice when looking at the cars for sale adds is there are a lot of really nice cars. But, when they show the undercarriage there are lots of them that have no fly wheel covers on the ******. That was something that I always installed on cars when I built them. Call me old fashioned but I felt it was a much needed item. Just wondering why it doesn't seem to be the case any more.
    Later,
  2. Dan Hay
    Dan Hay
    One time my dad got a rock wedged between the flywheel and torque convertor that rotated around and wedged against the block. It was because we pulled of on the rocky shoulder on the highway for something. Took us a while to figure out. Finally figured it out and dug it out with a big screwdriver.
    I have an SBC with a wilcap adaptor backed by a 39 box. the flywheel is open to the back of the oil pan but covered on the bottom. I guess it's fine, been like that for many years.
  3. low down A
    low down A
    because have you priced what that little pieced of stamped steel is selling for 75.00 to 150.00
  4. KevKo
    KevKo
    from Motown
    The guy that built my truck didn't put one on. I ran over one of those Mylar balloons. Yep, it got ****ed up into the bellhousing. Didn't hurt anything but made weird noises. I am currently totally rebuilding the truck, and it will have a cover.
  5. abonecollector
    abonecollector
    I had a bunch of N.O.S. G.M. flywheel covers, a few years back. One of the guys at work, was building a sbc model A ,he asked if i had one. I brought one in, gave it to him, & another guy asked "where does that go?" (He was not a car guy, his "car club" practically built his 53 for him)I like to keep things where they went originally, so, i put those flywheel covers back on
    jimmy six, catdad49 and Road Kill PU like this.
  6. Jeff Norwell
    Jeff Norwell
    MODERATOR
    You're not old fashioned.. you're smart.
  7. 56don
    56don
    They are getting hard to find around here. Every one I find seems to fit some alien spacecraft or something
    chevyfordman, low down A and Budget36 like this.
  8. Got 3 hanging on the wall for my 390 ford toploader ,non on the truck . Guess I will wait for a problem and then call myself a dumb *** !!!
  9. Flathead Dave
    Flathead Dave
    from So. Cal.
    I can't fathom why anyone wouldn't use one.
    WB69, Truckdoctor Andy, X38 and 4 others like this.
  10. HOTRODPRIMER
    HOTRODPRIMER
    If that's something that is old fashion I guess I am, I always use them. HRP
  11. oldiron 440
    oldiron 440
    I don't run a dust cover on my Ford or Mopars, air flow around the converter will help it cool. Both are high stall converters that don't even see gravel roads so I don't see the need.
  12. squirrel
    I finally put one on Plan II. Makes maintenance a bit more difficult, but looks better under there.
  13. Rickybop
    Rickybop
    Best to wear a cup.
  14. 57JoeFoMoPar
    57JoeFoMoPar
    I never ran one for years, my buddy who built my transmissions surmised it acted like a quasi-transmission cooler. Never had a problem. I'm going to run one on my latest project because it's so low.
    Thankfully on all my other cars the oil pan acted as a perfect skid plate to protect the converter.
  15. primed34
    primed34
    I've had a hot rod of some sort for a little over 50 years and never run one. Never even thought about until now. I've got 4 speeds and automatics and never had a problem.
    AHotRod likes this.
  16. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I should re-write my thoughts about this topic.. On an automatic....I imagine it makes perfect sense how the inspection plate would be a heat sink.....
    but when it comes to hotrods.... I only think Stick..... hahahah
    I keep my rotating parts covered.
    And you guys are right.. they ain't cheap..... $100-$175 for a tin plate.
  17. chevyfordman
    chevyfordman
    On the overdrives, I find that the plastic ones are hard to come by to nearly impossible.
  18. stanlow69
    stanlow69
    I ran a plastic one for a while. Would bottom out and it would start banging. Soo now for 50,000 miles without one. Oil pan acts as a skid plate. I wear out my oil drain plug every two years. From rubbing on the ground. I guess I`m just foolish. But I don`t have an I phone. So, who is old fashioned?
    AHotRod, Sancho and vtx1800 like this.
  19. David Gersic
    David Gersic
    from DeKalb, IL
    Yes. But that’s acceptable here. Encouraged even.
    My 37 came without the trans cover. I hit the local junkyard to find one. I think it was $5? Maybe $10? The bigger problem was that the mounting holes were stripped. Some helicoils fixed that problem.
  20. PhilA
    PhilA
    I'm old fashioned.
    There's a thousand and one dinks and chips out of the torus housing- something got caught and dragged round plenty.
    If GM didn't think it was worth fitting, they'd certainly have saved their nickels and not stamped that out and put it on.
    So I found one for sale and fitted it.
    Phil
  21. BamaMav
    BamaMav
    from Berry, AL
    One thing to consider is a lot of guys buy a crate transmission or one from a junkyard or a buddy who has one in his shop or garage, and none of them have the cover with them. Even the cars that I have parted out for the engine and transmission seldom have one. If the transmission has ever been out of the car, it’s usually missing the cover.
    I haven’t ran across one in years.
  22. squirrel
    The best one is the Tempest, where the torque converter just hangs out in the breeze under the back of the car.
  23. old chevy
    old chevy
    I have always installed them back. My dad insisted on replacing them so I did. That makes me old fashioned from way back I guess.
    Ed
    greener200, WB69 and PhilA like this.
  24. PhilA
    PhilA
    Can't fit a cover to that, think of the additional unsprung weight it would add!
    (Plus, it will reduce the effectiveness of the rear anti-body-corrosion system.)
    Edit: never mind, just spotted the rotoflex joints.
    hotrodjack33 and squirrel like this.
  25. lippy
    lippy
    from Ks
    I never realized how important they are till I read these posts. You can bet I'll have one on my next build. Lippy
    Oldiesmiles likes this.
  26. goldmountain
    goldmountain
    I put a cover on mine simply because I found one laying around. Straightened it out before I installed it and it immediately got a dent in it.
    5window likes this.
  27. spanners
    spanners
    Down here you won't p*** yearly inspection if it's not on. Same with racing at the strip in a street car.
  28. twenty8
    twenty8
    I always run one, but can anyone give the proper reason they have always been part of transmission/gearbox design?
    Surely it's not so if you run over someone, the ring gear doesn't eat their face off................o_O
  29. UNSHINED 2
    UNSHINED 2
    Everytime I get a old engine it seems like the first place the mice build a nest is in the clutch cover.....instant rot
  30. rockable
    rockable
    No, you are not. I always have one. 100 bucks is cheaper than damage or having to remove the ****** to fix the problem caused by not having one.
