Am I ready for MOKAN??????? Pic's
Discussion in 'H.A.M.B. Drag Nationals' started by Stewed, Aug 11, 2007.
  1. Stewed
    Stewed
    This is the view out of my garage as I am typing this post. Am I going to be ready???? HELL YES!!! These are the little elves that are out there helping the thing go back together faster so I know with all this kind of help in the 104 degree heat it shouldn't' be a problem!! Any of you farther along than me at this point or farther behind post some picks!!!!!!
  2. BinderRod
    BinderRod
    Brother I'm with you. I just got the Hot Rod re-jetted. Just some small stuff to go!!
  3. jerry
    jerry
    In the middle of the rerebuild of my t5.
    jerry
  4. Dirty2
    Dirty2
    Sweet , cant wait to see you there.
  5. guiseart
    guiseart
    ...nothing runs like a deere, baby - see ya there!
  6. Stewed
    Stewed
    Some progress. I got the engine and ****** back in and taking the drive shaft to be shortened in the morning. Any suggestions on the 700R4 shifter?? Everything should be back together and at the local drag strip for the Thursday night test and tune hopefully. If not I may have to find a nice straight stretch close to home this coming weekend to shake things out.
  7. BinderRod
    BinderRod
    I use a B & M Mega shifter with my 700R4. It took a while to get used to it. The funky thing is when you put it in park.
    The thing I don't like about the 700R4 is that it shifts out of low too soon. I believe I can adjust that out with the TV cable. I run 3.73 rear gears in mine but, I also drive it quite a bit on the street. What gears are you planning on running?
  8. AHotRod
    AHotRod
    Can't wait to see the car and meet ya there !
  9. Rusty
    Rusty
    Keep it moving
  10. REJ
    REJ
    from FLA
    Binderrod, I'm no expert on trannies, but I have two of the 700r's and one shifts out of low real quick. If the other gears are fine, you will not be able to adjust the low range shift with the cable. I talked to a tanny mechanic down here and was told that there are several different springs that can be installed on the low gear and it depends on which one you have that dictates where low shifts at.
    I tried to adjust mine out and second, third were shifting at almost 4000 rpm and the low gear shift never changed.
    On the other ****** in my 48 coupe, it shifts out at whatever redline is on the small block Chevy. It is set up so that overdrive locks in second gear which I'm sure will make a difference.
  11. bwiencek
    bwiencek
    Get the transgo 'no yo yo' kit SK700 - that should cure the shift point problems in early transmissions. They're a "shift kit" like what most of the good rebuilders put in for stockish rebuilds (not race/performance kits) - about $50 at the local trans parts supply house (I used to use MoKan in shawnee, ks when I worked out that way - now I'm downtown and need a different supplier)
  12. BinderRod
    BinderRod
    I think the transmission spring change will wait till this winter. Thanks for the help, Keith
  13. Rocky
    Rocky
    Classified Editor
    "Git 'er done"....see ya there.
  14. Stewed
    Stewed
    I BEEN BURNING MIDNIGHT OIL and progress is slower than anticipated but will be firing the beast tomorrow night and shaking the street!!! If I can figure out the video thing I may have a show for the HAMB if not then a few still pic's, either way I'll have a **** eating grin from here to next week when I leave to go to MOKANNNNNNNN!!!!!!!!!!!!
  15. weeds
    weeds
    see you down there , looking forword to it, weeds
  16. Stewed
    Stewed
    It wasn't planned this way but it only seems fitting that I got the Henry-J back together today as it is my old mans birthday,"WEEKENDER" on the HAMB. I got all the new goodies on and finally pulled it out of the driveway for a spin, of the tires that is. A few more little things tonight and it is on the trailer for the long haul to MOKAN on Thursday. It sure feels good to be behind the wheel again.
    SEEEEE YOUU AT THE DRAGGGGGG"SSSSSS!!!
    TIIIIMMMMYYYYY!!!!!!!
  17. flamedabone
    flamedabone
    Good for you. Nuttin like a last minute thrash.
    I'll keep an eye out for you on the road. I'm leaving thursday also.
    -Abone.
  18. trailer-Ed
    trailer-Ed
    from JC, MO
    Timmy, I hope to meet up with you. Your dad was a good friend. I first saw that J in Wentzville in the 80's I was like 14 or so, and when I was 19 I bought a stocker Henry J, dropped the front, and primered it gray, and drove it all over central MO, that was in about 93-94. That is when I met your dad and shade tree. we all 3 had J's and went to many cruises together. My J had Bevis and ****Head painted on the trunk and still had the stock banger in it. But loads of fun. I have several pix of your O'l man and shade and I parked together. Glad to see the yellow J back in action. I'll keep an eye out for your car so I can introduce myself. later, Rusty.
  19. Stewed
    Stewed
    I'll be easy to pick out of the crowd I'll be the one in blue jeans and a dark colored shirt. No realy I'd like to get a look at those pictures. I am bringing the photo album of my dad's that has the old car back long ago.
  20. ORGANGRINDER
    ORGANGRINDER
    hey stewed,
    i'm leaving from jacksonville, ark. at some point thur....mind if i tag along with you on the road? which direction you going?
    reggie
  21. ORGANGRINDER
    ORGANGRINDER
    binderrod....that looks like an international p/u in your header. you don't see too many...i have a 36 that my dad used to drive us around in before i could walk. when my new shop is finished i'm jumpin in the middle of that thing to get it on the road again.
    reggie
  22. Tudor
    Tudor
    from GA
    right on brother - see you soon
  23. BinderRod
    BinderRod
    Reggie... Good eye! It's a 39 International. See you at the Drags. Keith
  24. Stewed
    Stewed
    Wher the hell is Jacksonvill Ark.? If you would like I'll post my cell phone number here and anyone along the way can join in on the trip. I enjoy the company, and the security if I break down!!!!
    TIM MCCRAY
    (706)533-6798 cell with me unless I am having *** then it is not too far!!!!
  25. Stewed
    Stewed
    Just got home from the first road test---------------My old lady said I probably couldn't wipe the smile off my face with a FU########ing chainsaw!!!!!!!!!!!!!!!!!!!!!!!
    My **** is soooooo coooool I can't stand it... It may not be the fastest of the whole weekend but it dam sure will pull it's own weight!!!!
    MOKAN HERE I COME!!!!!!!!!!!!!!!!!!!!!!!!!!! Loading on the trailer tomorrow and will be west bound on THURSDDAY!!!!!!!!!!!!!!!!
  26. Henry J
    Henry J
    Hey Man....you're lookin good! I'll have to look you up when we get to the Kan. Just look for the purple/white Henry J
    Posey
  27. Stewed
    Stewed
    My gallon jug of midnight oil ran out and my **** is on the trailer after the neighbors cussed about the two minute burnout I did before I loaded it on the trailer, they gave me a standing ovation when they found out I would be out of town with it till Tuesday and not smoking up the KULL DE SACK till then!!!!! I am set on go and headed out in the morn,,,, FLAMEDABONE will probably blow by me at 9A.M but I will make it just the same, shy of a ****ING TORNADO blowing me into hell,,, I will be there!!!!!!!!!!!!!
    LOOK OUT JOPLIN!!!!!!!!!!!!!!!!
    STEWED SEE YOU THERE!!!!!!!!!!!
