am i wiring ignition correctly....
Discussion in 'The Hokey Ass Message Board' started by banditomerc, Jun 30, 2010.
  1. banditomerc
    banditomerc
    Well i am done hooking up my exhaust,engine is bolted in and i want to start the engine with just a basic starting circuit.I need your info(schematic would be nice)on how to wire it up so i can here it run with those dual smittys.
    I have a 350 engine with a Pertronix Flamethrower distributor with a black and red wire,and also the nessary Pertronix coil.I have no wiring at all.So please take me through the wiring to get it running.Thanks
  2. 6berry
    6berry
    u need a power wire hooked up to the starter and a good ground, there needs to be a wire coming off the coil to ground it and one to hook to the positive battery terminal, then the final wire goes from the starter solenoid to the battery positive. the final wire is what will control the starter so it just needs to be a wire that can be removed from the battery, not attached like the other wires
  3. claymore
    claymore
    AAAHHH like WHAT........... dude the coil needs a hot wire from the power source and the other side goes to the distributor not ground.
  4. F-6Garagerat
    F-6Garagerat
    yeah i had to read that a few times, all the while saying to myself "WHAT!!!!". that was way wrong.
  5. hotroddon
    hotroddon
    DO NOT ground the coil - ever. There are two wire on the PerTronix Dist, red and black. The red goes to the + side of the coil which should also have a full 12v power source when the key is in the run and start positions. The black wire goes to the negative side of the coil, there should be no other wires there unless you are running a tach.
    For the starter, you need the battery + cable wired to the starter. The battery - cable to a good ch***is ground and then a ground cable from the motor to the ch***is. The starter switch gets a wire from the switch to the starter solenoid on the 'S' terminal
    And our mufflers are SMITHY'S not smitty's :D
  6. banditomerc
    banditomerc
    Thanks fellas,and i stand corrected...its Smithy's! thanks hotroddon
  7. ricky from va
    ricky from va
    yup smitty is right. a ground on the coil just acts like a kill switch. not as terminal as it might seem lol
  8. kyle paul
    kyle paul
    from sac
    s on starter goes to s on ign
    r on starter goes to ign in ign
    +on coil goes to ign on ign
    batt goes to batt power
  9. banditomerc
    banditomerc
    What gives...i wired like hotroddonam said,and i am not getting a spark from the coil.What next.
  10. plym_46
    plym_46
    from central NY
  11. vtwhead
    vtwhead
    with the key on do you have a positive 12 volts on the + coil terminal?
    Is there 12 volts there when the starter is engaged?
  12. kyle paul
    kyle paul
    from sac
    just wire you ign like i posted ive done all my cars this way .
  13. 55 dude
    55 dude
    [​IMG] there ya go!:D
  14. banditomerc
    banditomerc
    Tried it again..still no spark out of coil. I have the battery+ to starter solinoid,battery grounded to frame,eng. block grounded to frame.I have a wire from + bat post to + on Pertronix Flamethrower coil,the red and black wires from the Pertronix Flamethrower dist are connected black to - coil,red to + coil.I hit the starter with a screwdriver...and get no spark from coil.....I am ready to chuk it and run a HEI dist(ugh!!)!
  15. 39 All Ford
    39 All Ford
    from Benton AR
    I don't know if the Petronics setup uses a full 12V, or if it needs to use a ballast resistor, if it uses a full 12 V then all of the **** running through the solenoid is NEEDLESS.
    If this is the case, run a hot wire from the battery (or ignition switch) to the + side of the coil, run the distributor hot wire to the same + side, put the - from the distributor on the - side of the coil, the car will make spark if the components are good.
    If you need to run 8 v on the petronics you will need a ballast resistor in the "run circuit", but if all you want to do is hear the mufflers the above SHOULD work for a few mins of run time, providing the petronics module wont take a dump if exposed to a full 12v.
  16. banditomerc
    banditomerc
    thanks,but still no spark.I think i will just pull it off and install the HEI!
  17. wbrw32
    wbrw32
    Smart move !!!!!!
