Am using 2pc mallory cap help
Discussion in 'The Hokey Ass Message Board' started by gasserjohn, May 16, 2012.
  1. gasserjohn
    gasserjohn
    Having problem with the ends of non real wire plug wire ends burning off
    using a msd box so need these type wires
  2. Old Guy
    Old Guy
    Get some real plug wires..
  3. GMC BUBBA
    GMC BUBBA
    Although the caps are made for solid wires the use of carbon wires will work IF you cut the wire clean and push it down really good on the pins. Then you got to keep the voltage down to prevent flashing and burning the tips off. Keep plug gap where the factory wanted it and make sure the carb ( or carbs ) are not running lean ( causes high voltage ) ........
    Glad to help....
    Jim
  4. 550Coupe
    550Coupe
    I use Mallory wires w/ 2 piece cap and have had no problems. Put on a Mallory Hi Fire ign. last year and no problems.
