Technical Ammeter pulses between 0 and + 15, what's wrong?
Discussion in 'The Hokey Ass Message Board' started by wisdonm, Sep 28, 2015.
  1. wisdonm
    wisdonm
    Brought a late '6os Ford out of a 13 year hibernation. The ammeter rhythmically pulses from 0 to +15 amps. The instrument lights pulse with it. It has a Ford alternator with external regulator. The alternator and regulator were less than a year old and working fine before the long sleep. Any ideas on what's happening or fixes?
  2. Load it up with heads lights and all the other electrical. I think if it stills pulses you have either a regulator problem are a diode in the alt. IMHO
  3. bedwards
    bedwards
  4. stimpy
    stimpy
    sounds more like a bad diode trio in the alternator ( they die unexpectedly ) , if not the instrument panel lights power regulator ( ford has this in the dash )
    also the contacts on the voltage regulator might be dirty and causing it to act up too . lots of things corrode and break while in long hibernations .. pull the VR cover and do a quick reset on it .
  5. llonning
    llonning
    What bedwards said. Bad ground between engine and body on the last one I had that issue with.
    Len
  6. Two shabby
    Two shabby
    Another vote for bad ground
