Technical Amp Meter Full Discharge
Discussion in 'The Hokey Ass Message Board' started by Steves46, May 14, 2025.
  1. Steves46
    Steves46
    from Florida
    The 6 v pos ground voltage regulator or generator has been acting up in my 55 F1 hundred. For some strange reason, my amp meter is showing full discharge even though my battery is disconnected. Is there a possible explanation for this?
  2. manyolcars
    manyolcars
    yes. it is fried
    Budget36 and 302GMC like this.
  3. Steves46
    Steves46
    from Florida
    That’s what I was afraid of. Since I have an auxiliary volt meter, I’m not gonna worry about replacing the amp meter anytime soon.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I’d at least put both leads on one post rather than have voltage flowing thru the gauge via the two posts.
  5. miker98038
    miker98038
    ^^^^. Good idea
    seb fontana and trulyvintage like this.
  6. Steves46
    Steves46
    from Florida
    Johnny, thanks however I am not sure I understand your recommendation. Are you suggesting I remove the connection from the faulty amp meter and just use the under dash volt meter gauge as the sole p*** through?
    trulyvintage likes this.
  7. Budget36
    Budget36
    On the back of the ammeter you have two wires, each on one “post” bolted down.
    He’s saying disconnect one of the connections and move it to the other side, in effect just byp***ing the meter.
    Make sure the battery stays disconnected while you do this.
  8. Steves46
    Steves46
    from Florida
    Gotcha. With my voltmeter, there are no connection post rather there is a circular bracket the wire p***es through.
  9. 5window
    5window
    Weird. can you post a photo, please?
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Sorry, did not realize you had a p*** thru style meter. Your good as is. IMG_4097.jpeg
    Budget36 likes this.
  11. winduptoy
    winduptoy
    Induction amp meter...cool
    the needle might just be stuck....maybe a few light taps on the backside with a screwdriver handle...
    just a thought....
  12. Steves46
    Steves46
    from Florida
    I was thinking the same and will try when I get home tonight.
  13. RodStRace
    RodStRace
    The inductive amp gauge is MUCH safer than a p*** through. Id also suggest it's just sticking.
    There might be something magnetic going on in back, too.
    If the tapping doesn't fix, try looking up old service tips from the era. The big three always had bulletins and such for issues.
    warbird1 likes this.
  14. Dave G in Gansevoort
    from Upstate NY
    Damn, you guys are good! I just learned something today. Never knew about p*** through amp meters. Always thought they were only the wired kind in vehicles. Neat!
    winduptoy likes this.
  15. Budget36
    Budget36
    Yes, I wasn’t aware Ford was still using them that long.
    He’s fine as-is.
  16. Mr48chev
    As far as electrical issues go the only real issue with an inductive ammeter is that old wiring might shake and wear through where it goes through the loops and short out. Otherwise it is just the magnetic field of current flow moving the needle.
  17. If you are brave enough to take your meter apart (and a quick tap doesn't set it right), you may find it is a small iron filing, etc that is stopping the movement from returning (easy fix, just remove the filing), or the return to centre hairspring is broken or one end has detached.
  18. Steves46
    Steves46
    from Florida
    Good news. A few taps on the back of the gauge did the trick. Thanks for everybody’s input.
    Johnny Gee and RodStRace like this.
  19. RodStRace
    RodStRace
    Thanks for the follow up.
    Ya know, they built those old trucks for washboard roads. I think yours is being driven too smooth. :p:D
    mountainman2 and Steves46 like this.
