"AN" Brake Flaring Question
Discussion in 'The Hokey Ass Message Board' started by TagMan, Feb 4, 2009.
  1. TagMan
    TagMan
    I've always used 45° brake line fittings in the past, but I'm going to be using "AN" brake line fittings for the first time on a project. I can't seem to find a 37° double flaring tool. I have sleeves that go in the female fittings - do they take the place of a double flare?
    Thanks,
    -Bob
  2. HemiRambler
    HemiRambler
    Yep the sleeves take the place of a double flare. The 37 degree an flaring tools are harder to find.
    I bought a cheapy from speedway - I wouldn't reccomend you getting it. I immediately stripped the screw threads (replaced it with a grade 8 bolt) then I later chipped the dies - very dissapointed considering what it cost.
    Look for a Rigid or Imperial or some other Good Brand
  3. chopolds
    chopolds
    from howell, nj
    I don't believe you need to do a double flare on a 37* fittings, mine is a single flare tool. And the sleeve is jsust backup, for extra clamping strength.
  4. chevymike
    chevymike
    Nope, single flair only. The stepped part of the sleeve goes away from the end, so the nut will slide over the step. When you tighten the nut to the AN fitting, the larger part of the sleeve helps to compress the flair evenly onto the AN male fitting.
    As for the tool, I got mine at Summit Racing and has worked fine for me. BTW, I am not using Stainless Steel tubing, which if you do, you need a heavy duty version that works with stainless. Most of the basic ones are not rated for this and will self distruct fairly easy.
    My .02 worth.
  5. carbon guy
    carbon guy
    from indy
    I have a flairing tool by Ridgid, that works great for stainless tubing. They are abit pricey, around $100 or so. Uesd it on race cars and hot rods.
  6. RichFox
    RichFox
    I also have a Ridgid. Got mine at the airport. Great place for 37 degree stuff.
  7. krylon32
    krylon32
    from Nebraska
    I'm on my second Ridgid 37 degree flaring tool. We do all stainless and they work great. I keep the old one as a spare after I sent it back to the factory for a rebuild. They have a feature which does not let you over flare the tube which can lead to failure. Pricey, but what's to much when its brakes?
  8. Wesley
    Wesley
    Aircraft Spruce is another good place for -AN stuff
  9. TagMan
    TagMan
    Thanks for the info !
    -Bob
  10. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    My Ridgid does a great job as well.......Littleman
  11. BillyB
    BillyB
    Another good source is Wicks Aircraft Supply in Highland Illinois. They sell a great flaring tools and all the fittings. Prices are reasonable.
  12. hot rust
    hot rust
    another place is godmans in memphis tn of the tennessee bollweevel funny car fame. they handle the imperial brand and also all types of benders and tubing supplies. Ask for joe, he's the man.
