Technical AN Fitting
Discussion in 'The Hokey Ass Message Board' started by Doublepumper, Nov 19, 2025.
  1. Doublepumper
    Doublepumper
    from OR-WA, USA
    I want to use a male 6 A-N fitting on a late model Quadrajet fuel inlet housing. Before I buy one, will an inverted flare fitting work to replace the original tube nut and flared tubing? Does the inverted flare on the A-N fitting have the same 45 degree taper as the original flared tubing?
    I know there are A-N adapter fittings to replace the factory fuel inlet housing...I don't want that. I want to use the factory carb fuel inlet housing and screw an A-N fitting into it.
    Thanks for the edjamacation!
  2. squirrel
    Post a link to the part you are planning to buy, maybe we can help you figure it out.
  3. DDDenny
  4. rockable
    rockable
    First of all, AN is a 37 degree flare. Inverted flare and SAE flare are 45 degree. They are not compatible with each other. If you put a -6 AN male on your carb, you need to match it up with a -6 AN female swivel fitting or a flared tube end with a -6 AN nut and -6 AN ferrule. It also requires a 37 degree flaring tool, if you decide to flare tubing.
    Weedburner 40, jet996, Oldb and 4 others like this.
  5. squirrel
    pnevells, jet996, 325w and 7 others like this.
  6. 19Eddy30
    19Eddy30
    from VA
    Op & others stick with Name brand
    A/N or Jic
    Especially on the aluminum ones,
    One's you see that are off brand are under cut , & if weighed on gram scale
    There lighter , crack under vibration
    Easily,
    Even just tightening to correct torque,
    Anodize less mills , not corrosive resistance , & not correct wrench size's,
    Not correct spec Aluminum grade.
    jet996 likes this.
  7. Doublepumper
    Doublepumper
    from OR-WA, USA
    Winner, winner, chicken dinner!
    I wasn't sure about the angle of the reverse taper in the fitting.
    I have a Parker JIC, but didn't want to snug it up without first knowing whether it was going to destroy the tapered seat in the carb inlet housing.
    Thanks fellers!
  8. rockable
    rockable
