Technical An unsightly discharge
Discussion in 'The Hokey Ass Message Board' started by Chappy444, Nov 15, 2019.
  1. hotrodA
    hotrodA
    Eeewwww. Time for a short arms inspection. Report to sick bay.
  2. Ebbsspeed
    Ebbsspeed
    That's probably from the car wash......;)
  3. seb fontana
    seb fontana
    from ct
    I have noticed that black liquid coming out the exhaust, more on some cars than others when cold.. My sbf would drip a descent stream and make puddles, strange is it doesn't do that anymore.. Would leaded gas make more moisture than non-leaded? What about carbon build up? I have one engine that the piston tops pretty clean but the comsution chambers/valves are as nasty as one could think..
  4. Happydaze
    Happydaze
    Bit late to this party. I call BS on these fancy, scientific explanations. That black stuff is special, magic liquid that helps show you where your exhaust leaks are. Exhaust leak tracing liquid, find it in the isle next to Blinker Fluid.
    Chris
    seb fontana and Hnstray like this.
  5. seb fontana
    seb fontana
    from ct
    Blimey, you not just late to the party, yer at the wrong house!
    lothiandon1940 and Happydaze like this.
  6. hotrodjack33
    hotrodjack33
    PARTY ? Did someone say PARTY ??? I'll bring the black hydro-carbonized fluids:D:eek:
    lothiandon1940 likes this.
  7. Joe Warren
    Joe Warren
    My AV8 does it; my Jaguar does it; my Honda does it; I do it... Just the time of year. Don't be embarr***ed. Just wipe yourself and go on with life.
  8. Roothawg
    Roothawg
    The roadster does the same thing. It has turn downs on the exhaust, so it marks it's spot. The wife is ecstatic.
    Truck64 likes this.
  9. Looks way rich, rejet/adjust mixture, choke, clean aircleaner.
    Lloyd's paint & glass likes this.
  10. the oil soup
    the oil soup
    from Tucson,AZ
    I considered joining the military but was afraid I would get a discharge.
    seb fontana likes this.
  11. ZZ Top Chop
    ZZ Top Chop
    I was scared to open this thread
  12. deathrowdave
    deathrowdave
    from NKy
    As air is compressed it creates heat , the burning of fuel is as Squirrel explained . Even if you did nothing but compress the air in your engine , it would create heat and when exiting in to a cooler place it will condense and create moisture . Ever drain the tank on your compressor ? This water is from the heat of compression escaping .
  13. Rocky
    Rocky
    Classified Editor
