Projects And it begins.....
Discussion in 'Traditional Hot Rods' started by Lowbuckboz, Oct 13, 2013.
  1. Bam.inc
    Bam.inc
    from KS
    That looks cool, please share some tech & photos as that steering is installed. I like it.
  2. Lowbuckboz
    Lowbuckboz
    Will do. I'm a little ahead of myself. Not ready for the column, grabbed it while I was in the middle of the parts pile. I have to finish the crossmember.
  3. Lowbuckboz
    Lowbuckboz
  4. woodbutcher
    woodbutcher
    :D Nice looking car.My Father had a 29 also just like yours.Except for the color.His was Dark green body with black fenders.
    Good luck.Have fun.Be safe.
    Leo
  5. Lowbuckboz
    Lowbuckboz
    Thanks man!
  6. Lowbuckboz
    Lowbuckboz
    Adapted the bell housing mounts. ImageUploadedByH.A.M.B.1394496296.083345.jpg ImageUploadedByH.A.M.B.1394496308.992620.jpg
  7. Lowbuckboz
    Lowbuckboz
    F1 brake pedal ***embly is in. Relocated inboard. Have to heat and bend the brake pedal arm, hits the bell housing at the starter. Now time to weld in the crossmember.
  8. Lowbuckboz
    Lowbuckboz
    This engine angle is way better. It's at 2* down from front to back. ImageUploadedByH.A.M.B.1395615089.839563.jpg
  9. Babar40
    Babar40
    from Florida
    Everything looks terrific so far, keep up the good work!
  10. Lowbuckboz
    Lowbuckboz
    A little heat and the brake pedal clears the bell housing. Need to remake the bell housing mount for pedal travel. A few more things to do here. ImageUploadedByH.A.M.B.1395834960.902411.jpg
  11. Lowbuckboz
    Lowbuckboz
    Wheels just picked up from the powder coater!
  12. Lowbuckboz
    Lowbuckboz
    Took a useless clutch shaft, not sure how it worked, and made it work for me. I needed a longer version. Now it's straight and longer. ImageUploadedByH.A.M.B.1396008814.698309.jpg ImageUploadedByH.A.M.B.1396008827.875600.jpg
  13. Lowbuckboz
    Lowbuckboz
    Love when the fedex guy shows up! ImageUploadedByH.A.M.B.1396022667.874121.jpg
  14. Lowbuckboz
    Lowbuckboz
    More stuff arrived. ImageUploadedByH.A.M.B.1396025559.650422.jpg ImageUploadedByH.A.M.B.1396025575.098627.jpg ImageUploadedByH.A.M.B.1396025597.081518.jpg
  15. Nice package fedex dropped off!!:)
    Is that a harmonic balancer?
  16. Lowbuckboz
    Lowbuckboz
    It's a high speed pulley. Can't wait to get the cam. Should run good.
  17. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    hell yeah! lookin great man!
  18. Lowbuckboz
    Lowbuckboz
    Thanks! It's slow going but I am making some progress. I'm now figuring out valve spring pressures with shim thickness for the cam I plan to use. I'm hoping this car runs good. Already know I'm going to need another stromberg.
  19. Lowbuckboz
    Lowbuckboz
    No luck with rears. This one had water in it. I've got one more to inspect. ImageUploadedByH.A.M.B.1396704766.146662.jpg
  20. Lowbuckboz
    Lowbuckboz
    Such a great idea! Worked great. Not welded in yet. ImageUploadedByH.A.M.B.1396833394.490111.jpg ImageUploadedByH.A.M.B.1396833415.149721.jpg ImageUploadedByH.A.M.B.1396833427.809453.jpg
  21. Lowbuckboz
    Lowbuckboz
    Ready for mock up. Next, torque tube. ImageUploadedByH.A.M.B.1397256592.367433.jpg
  22. Lowbuckboz
    Lowbuckboz
    ImageUploadedByH.A.M.B.1397866226.413456.jpg ImageUploadedByH.A.M.B.1397866238.873020.jpg ImageUploadedByH.A.M.B.1397866249.540985.jpg
  23. Lowbuckboz
    Lowbuckboz
    Rear ride height is set. Torque tube is correct length. ImageUploadedByH.A.M.B.1398629443.884379.jpg ImageUploadedByH.A.M.B.1398629452.454199.jpg
  24. 3wLarry
    3wLarry
    from Owasso, Ok
    go man go
    kidcampbell71 likes this.
  25. olskool34
    olskool34
  26. bartmcneill
    bartmcneill
    from Ada, OK
    If you chop the top, I would like to see that. Probably not too hard but I've never seen it.
  27. Lowbuckboz
    Lowbuckboz
    I'm going to take 3" out of the top and rake the windshield back. I'll post it all.
  28. Lowbuckboz
    Lowbuckboz
  29. 3wLarry
    3wLarry
    from Owasso, Ok
  30. Lowbuckboz
    Lowbuckboz
    ImageUploadedByH.A.M.B.1398988911.276099.jpg ImageUploadedByH.A.M.B.1398988935.232551.jpg Bill makes some nice stuff! Absolutely beautiful!
