Projects And it begins.....
Discussion in 'Traditional Hot Rods' started by Lowbuckboz, Oct 13, 2013.
  1. Lowbuckboz
    Lowbuckboz
    @ b-bob, no problem! Anything I can help ya with, just ask!
  2. b-bob
    b-bob
    Mike, I need to change the bells on the stock one, and a friend has the fordy available.
  3. Lowbuckboz
    Lowbuckboz
    My stock rear had wore out axles at the hub. Wasn't worth fixing mine with a V8 rear available. Also b-bob, the center drive shaft measured 48 7/8". With a 50 5/8" torque tube. I didn't clarify that in my last post.
  4. b-bob
    b-bob
    Thank you again, I think I could do the outer shaft myself, but I am thinking the center shaft would have to be machined on the end. They don't just cut and weld it do they? Then again it is just a stock 4-banger.
  5. Lowbuckboz
    Lowbuckboz
    Get a 33-34 Ford driveshaft. The pinion splined end is pressed into the shaft and then welded from the factory. Basically, undo what Ford did, shorten, repress the coupler back in. You may have to clean up the part of the coupler that is pressed into the tube. Best to do the job on a lathe so you can monitor straightness while welding. Make sure not to use too much heat, the splines can be damaged in the coupler. Keep in mind what rear you are using as far as spline count. I used a 35 that has 10 splines.
  6. b-bob
    b-bob
    Great info,this helps a lot. I will start searching for a shaft but may not be easy in this part of the world.
  7. Lowbuckboz
    Lowbuckboz
    Standard issue wheels and tires.
    firepilot likes this.
  8. Atwater Mike
    Atwater Mike
    Yessir, no reason for that aftermarket stuff those young whippersnappers use. Standard Issue, look to be the right recipe for that 'Cl***ic Roadster Tilt'!
    Love this project, helped a friend do up his restored '30 his wife bought him in '76.
    It was a black car, full fendered, SBC, but sure was clean to work on. (just like a new 'A' roadster!)
  9. Lowbuckboz
    Lowbuckboz
    I love that tire rake look! No aftermarket here!! Thanks man!
  10. Lowbuckboz
    Lowbuckboz
    Tail lights!
  11. Lowbuckboz
    Lowbuckboz
    Now I've got to mount em.
  12. Lowbuckboz
    Lowbuckboz
    How about a nice 1A cam grind from Jim Brierley. I'll take it! ImageUploadedByH.A.M.B.1405455254.719267.jpg
  13. Binger
    Binger
    from wyoming
    I just read through this whole thread and I like what you have going on. I am always glad to see banger powered rods.
  14. Lowbuckboz
    Lowbuckboz
    Banger powered hot rods are awesome!
    LSGUN likes this.
  15. waxhead
    waxhead
    from West Oz
    Agreed
  16. Lowbuckboz
    Lowbuckboz
    Front end in and mocked up. Tweak this, bend that and wait for parts. Should be a roller next week.
  17. HelmuthBrothers
    HelmuthBrothers
    from New Jersey
    Looks awesome man! Good choice on the tail lights!
  18. King ford
    King ford
    from 08302
    Head for hopewell when you get her runnin boz, they have a nice cruise in at the Amish market about every third Friday !
  19. Lowbuckboz
    Lowbuckboz
    Thanks bro! I'm happy with the lights.
  20. Lowbuckboz
    Lowbuckboz
    I'll be up there for sure! Been there a couple of times with my coupe.
  21. Lowbuckboz
    Lowbuckboz
    Some more progress. I'm just diggin how the pic looks. Lol
  22. Lowbuckboz
    Lowbuckboz
  23. snot275
    snot275
    Cool build dude! I ****ing DIG that color!!! The direction of this car is making me giddy inside
  24. Lowbuckboz
    Lowbuckboz
    Thanks man! Next winter I'll do the body, same color.
    As for today, pie cut bones and set caster.
  25. Lowbuckboz
    Lowbuckboz
    Getting to be too nice for the sand.
    ImageUploadedByH.A.M.B.1406518413.806521.jpg ImageUploadedByH.A.M.B.1406518435.952410.jpg
  26. Lowbuckboz
    Lowbuckboz
    Bones extended and caster set.
    ImageUploadedByH.A.M.B.1406603035.332153.jpg ImageUploadedByH.A.M.B.1406603051.355730.jpg
  27. Lowbuckboz
    Lowbuckboz
    Looking like something.
    firepilot and Mad-Lad like this.
  28. CaliDreamin'
    CaliDreamin'
    Dig this car.
    "Insert Epic Quote Here"
  29. Ford Mike
    Ford Mike
    Oh boy that rules!
  30. waxhead
    waxhead
    from West Oz
    WOW, very nice, making good progress.
