Technical Angle milling flathead heads
Discussion in 'The Hokey Ass Message Board' started by treb11, Sep 28, 2020.
  1. treb11
    treb11
    Can you angle mill flathead heads to increase compression without having to worry about the valves hitting the top of the chamber?
    It seems at some point that the head bolts or stud nuts would become a problem.
    Sent from my SM-G965U using The H.A.M.B. mobile app
  2. TCTND
    TCTND
    You can simply mill them flat then add some clearance over the valves. Flatheads are tricky; Jerry Branch got more power out of Harley KRs by improving flow at the expense of compression.
    jimmy six and dan c like this.
  3. jimmy six
    jimmy six
    Get flow and spin the **** out of it.... bigger bangs or more of them... take your pick.
    Tman likes this.
  4. rusty valley
    rusty valley
    yes, they do angle cut them, lots of threads at the barn about it. better combustion is the result. 50 thou clearance over the valves, and i forget the angle, tubman will chime in, he knows
  5. FrozenMerc
    FrozenMerc
    The problem with Ford flatheads is the block (ports) can be as big of an impedement to good flow as the heads / valve area, especially on the exhaust side of things. The HD KR didn't have that problem, but 60 hp out of 45 ci is, without a doubt, the gold standard for flathead engine performance. That is equivalent to a 320 Hp - 239 ci 8BA and HD did it running 6:1 compression.
    Look up the work Mark Kirby did 20 years ago or so when he had Motor City Flatheads. He published a ton of info on the air flow characteristics of the flathead, most of it is still very relevant.
