Hot Rods anglia /austin gassers at the meltdown questions ??
Discussion in 'The Hokey Ass Message Board' started by carryallman, Jul 15, 2017.
  1. carryallman
    carryallman
    anybody know what the blower anglia /austin gassers{ that was at the meltdown } what rules they run under ?? anything posted anywhere ?? thanks
  2. squirrel
  3. carryallman
    carryallman
    i know there are certain build rules at the meltdown -but was wondering what all the scott rods guys build there cars by ? i did notice the green anglia used a stock type front frame rails -most the other cars used sq. or rect tube / all the cars had ladder bars / it just seems like if a guy was building a gasser -scott rods type car -it would be nice to see a list of some info ?? kinda like a nhra handbook ?? just curious ! after a w/end of watching the "scott cars " im hooked ! plus they was all very nice to answer a lot of my questions in the pits !! thanks guys -I REALLY ENJOYED THE SHOW YOU PUT ON !!-
    jwells724 likes this.
  4. squirrel
    the problem with the meltdown is that it's over too soon, you don't have time to absorb it all, then go back and look and ask questions again.
    Nice talking to you in real life, btw!
    lothiandon1940 likes this.
  5. micky69
    micky69
    from Ohio
    The rules are posted on our Facebook page. Stock frame, or 2X3 rails are it, no tube cars. Ladder bar rear and straight axle fronts only. 6-71 blowers, some basics. Any questions any of the guys will answer.
  6. Description
    ScottRods AA/Gassers - Nostalgia drag racing match race organization presented bywww.scottrodscustom.com
    ScottRods AA/Gassers Rules and Guidelines
    1.) Body/Stance: Any traditional AA/GS body style that was run from '62-'70. Anglia, Willys Coupe, Panel or Pick-ups, Henry J, Austin, Opel Kadett or Corvette up to '67. Must have a nose high or rear rake. Period correct look. No slammed Pro Mod style front ends, wings, or dropped over rear fenders, etc. Must have vintage look, with no radical mods. Other make/models will be reviewed on a case-by-case basis to fit within the group’s appearance guidelines.
    2.) Wheelbase: 90” min. to 105" max. wheelbase.
    3.) Fuel: Gas or E85, or methanol. No nitrous or nitromethane permitted.
    4.) Engine: Cast iron or aluminum heads allowed. Cast iron blocks preferred.
    5.) Supercharger: Standard non-billet rotor 6-71 roots blower (strips ok). Maximum overdrive 20%. Stock top and bottom opening. No helix permitted.
    6.) Injection: Retro period style injector, 4-port, bug, small barn door, etc, or carbs with Hilborn scoop. No Bird or bigger or carbon injectors permitted. No dominator carburetors. No port nozzles.
    7.) Fuel Pump: Limited to Hilborn 150-1 or 80-A-1, Enderle 110. (may review on a case by case basis to fit others (RE: elec pumps)
    8.) Ignition: Magneto Ignition, Super Mag II or Vertex, No MSD Mags. MSD box and distributors allowed on case by case basis. Boxes must be hidden.
    9.) Suspension: Ladder bar rear suspension only. Factory boxed or 2X3 rectangle full frame front to rear. No tube chassis or half chassis cars. Straight front axle mandatory.
    10.) Wheelie Bars: 45" max from center line of axle. No single bars. Must be dual wheel type. No lightweight materials (i.e. Carbon fiber or titanium).
    11.) Wheels: Period correct appearing wheels (no Rod lights, Centerlines, Welds, etc). If you're not sure, please ask.
    12.) Slicks: 12" rear tire max. Can be sidewall designated. 10.5"-12" tires preferred.
    13.) Electronics: No transbrakes for launch, footbrake only ( trans brakes only for back up use only if pro brake tranny).
    14.) Transmission: Full automatic OEM transmissions only with torque converter. No Lencos, Brunos or clutchless transmissions. No electronic or air assisted shifters, must be manually shifted.
    15.) License and Chassis Cert: IHRA/NHRA LICENSE AND CHASSIS CERT (Both are recommended for insurance and your safety)
    The ScottRods AA/Gassers run a heads-up, 5.60 index for 1/8th mile, and 8.85 for 1/4 mile, 4-tenths pro tree start. (CHASSIS CERT LIMITS ENFORCED THOUGH) cars paired up by e.t. for best side by side racing. 1/8 or 1/4 mile events dictated by event and venue. Preferred performance ranges: 5.50-5.90 for 1/8, and 8.60-9.0 for 1/4.
    Safety and showmanship most important! New members are welcome, but will need to be voted in by current members after auditions and interaction with the group. This could take a few events. People are our asset.
    MOST IMPORTANT --- HAVE FUN AND PUT ON A SHOW!!
    Send Email
    View Website
    Suggest Edits
    Report a Problem
  7. carryallman
    carryallman
    has anybody ever weighed there anglia drag car on each corner?or front end & back end ?? just curious ? i would really like to see what the "scott " cars weigh ??
  8. carryallman
    carryallman
    how about more anglia "gasser " pics !!!!
  9. carryallman
    carryallman
    anybody know what size tires some of the scott rods anglia gassers was using ?? they was on 10" rims ??
