Hot Rods anglia front end ?
Discussion in 'The Hokey Ass Message Board' started by smitty1948, Dec 22, 2010.
  1. smitty1948
    smitty1948
    from new york
    anglia front axle question looking for a hub to hub front axle width building a 48 anglia gasser
  2. brandon
    brandon
    want to say mine was 38" king pin to king pin....old ford spindles , buggy spring and hairpins. tires were at the edge of the fender ...used a magnum metric disk kit. 15x4's with 145's........spindle mounts were under the fenders another 1 .5 or so inches......
  3. GEORGE TAYLOR
    GEORGE TAYLOR
    from MAINE
    my 48 is 38" pin to pin custom length from speed way
    i have a shorter one 34" if you are interested
  4. Flat Ernie
    Flat Ernie
    Tech Editor
    I think the track width of the original car is on the order of 48"...couldn't tell you the pin-to-pin dimensions
  5. hemigeorge
    hemigeorge
    41 and one quarter inches
  6. hemigeorge
    hemigeorge
  7. Larry T
    Larry T
    Stock Anglia is 41+ kingpin to kingpin. I think the stock trackwidth is 46 1/2 (if I remember correctly). If you put spindle mount wheels on the stock axle you end up with around 48 trackwidth.
    I've got an aftermarket (Specialty Cars) axle for Ford spindles in an Anglia. It's 37" kingpin to kingpin and gives a 47" trackwidth using Magnum hubs and disc brakes.
    Larry T
  8. Mine is 36" King pin center to center. 5.5 inch drop with leaf springs. Early 50's Chevy spindles with a Magnum disc/hub kit. The tires tuck up perfectly in the fenders with a 15x4 wheel and a 5.60x15 tire.
    Good luck on the build, lets see some pics!
