anglia spindles.... what axle can i use
Discussion in 'The Hokey Ass Message Board' started by Rocket-Boy, Oct 28, 2010.
  1. Rocket-Boy
    Rocket-Boy
    hi i have a set of 5 spoke magnesium spindle mounts that suit anglia spindles, i got a hold of a whole anglia front end but the axle is way to narrow for my build (a model frame) i have tried the old search button already but cant seem to find anything, what axle can i run with anglia spindles? i beam axle
    thanks guys
  2. The37Kid
    The37Kid
    Have then crack tested then get back to us. I'd have a set of 39-48 Ford spindles turned to fit if you plan to put this build on the public roads.
  3. Rocket-Boy
    Rocket-Boy
    thanks for the help, yeha id like to run it on the street.... the anglia spindles did scare me a bit and im a brave man. running an olds with hydro so the weight will be up there
  4. The37Kid
    The37Kid
    The guys running vintage Lotus 7's and 11's don't trust them, and Coventry Climax engines are half the weight of an Olds.
  5. Rocket-Boy
    Rocket-Boy
    yeah they are a heavy sucker, thanks heaps. i belive i should be finding myself a set of 39-48s
  6. By 'brave' you mean GAY and by 'man' you mean MIDGET .......right!!!!
  7. Rocket-Boy
    Rocket-Boy
    you had me at gay midget
  8. NORSON
    NORSON
    I used a set on my altered in '66 with American spokes. It had a Rat in it. Used the Anglia axle as a jig with 4130 bosses and tubing. didn't break when I ran over that curb. Probably not a good idea for the street. cool for the strip. :D
  9. MilesM
    MilesM
    I aquired a set of Ford spindles that were machined down to Anglia spec.
    I do not know anyone that does this but it is possible as I have a pair.
    I beleive all the Anglia stuff you bought will not be usable for the street.
  10. need louvers ?
    need louvers ?
    P.M. John Evans here on the board. This is right up his ally as far as machine work goes.
  11. Larry T
    Larry T
    Lots of gassers/altereds/dragsters used them. If you're afraid of them on the street (and I might be) how about using Mark Williams/P&S/Strange spindles. The would probably hold up and are the right dimensions. Mark Williams also makes axles that work with the spindles.
    Larry T
  12. I think I'd be much more worried about the MAGNESIUM 5 spokes that are 40+ years old .....
  13. toddc
    toddc
    Is there enough material in the centres of the wheels to machine them out to full size Ford bearings?
    And where are these gay midgets???
  14. Larry T
    Larry T
    No.
  15. rodrobb
    rodrobb
    from Sweden
    I use Volvo pv spindles on my spindle mounts, bigger than anglia smaller than Ford
    and then machined the wheels to fit the volvo bearings.
  16. Rocket-Boy
    Rocket-Boy
    yeah i may go the machine down a ford set path. the sheer weight of an olds and hydro on such little spindles scares me a little.
    oh and sorry guys all out of the gay midgets
