Technical Anglia/Thames front Suspension set up pics needed
Discussion in 'The Hokey Ass Message Board' started by Mitchell Rish, Jan 1, 2026 at 10:46 AM.
  1. Mitchell Rish
    Mitchell Rish
    from Houston MS
    I am thinking again which is always dangerous. No secrete I have a couple. I am wanting to see how everyone out there put transverse leaf /straight axle/hair pin set ups in
    AND
    How those of you that used the coil overs did it.
    Any experiences that you guys can throw in is a plus.
    Yes I have had a transverse set up before but not this narrow. ( batwings at 30 in) so I am figuring a 26? Wide spring minus a leaf.
    I have a 4 inch drop axle ( 42 king pin to king pin. From WAK.
    I have both coil overs /and leaf spring set up -I am looking to see cleanest and steadiest. ( Everyone knows the little animals have an evil tendency if things aren’t watched close.)
    I like to see what everyone has done. Can’t get better than you guys.
    And Happy New Year.
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I built mine with a MII IFS on one and an Opel GT on the other, but here's pics of the original ch***is (with a narrowed '37 Ford axle), if that helps. '37 axle 01.jpg '37 axle 02.jpg '37 axle 03.jpg '37 axle 04.jpg '37 axle 05.jpg '37 axle 06.jpg '37 axle 07.jpg
  3. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Thanks FTF. I have seen a ford econoline axle and a Chevy early 60s cube van axle shortened. Using parallels.
    I am at a toss up on whether to stay with the transverse or go to coil over. I have a couple of axles to chose from. I narrowed the axle under the Prefect. And it also runs parallels. As does the Kadet and Willy’s. The nature of a transverse is duley noted over the years but I still see a lot in race cars. I even had one on my first front engine rail no issues per say.
    I have to get the tires under the fenders on the Thames like the others. It bugs me badly.
  4. Mitchell Rish
    Mitchell Rish
    from Houston MS
    This is stance now
  5. Kerrynzl
    Kerrynzl
    Personally I would do the above
    With cross steer and use a Panhard bar parallel with the drag link
  6. Mitchell Rish
    Mitchell Rish
    from Houston MS
    I have everything to do that just comparing and looking. Mr Langdon kept them up there didn’t he.
  7. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    One of the hardest issues on the Anglia/Prefect/Thames is getting the front tires under the fenders, while maintaining good steering and engine / ch***is clearances. On our first Anglia build my son and I chose an Opel GT transverse leaf front suspension. It was almost narrow enough. At the risk of getting this post banned for being O/T I won't post a photo of the suspension (think Corvette transverse leaf). But you can see that it could have used another half inch or so of inset. Maybe a wheel with another 1/2 inch of inboard offset spacing would do it. (We used Vega front rims).
  8. Mitchell Rish
    Mitchell Rish
    from Houston MS
    I get it. I narrowed a previous axle left over from another project in the Prefect. We narrowed a 4 inch drop axle we had for the Kadette also.
    But you are correct. The Blair’s Speed Shop car has the coil spring set up and I can mimic it but I am going to use a cross steer box with the arm turned forward and keep the cross rod etc behind the axle. I am looking at 3-3 1/2 inches travel max on Thames.
