ANGRY BIRD, THE TRI 5 T-BIRD HOT ROD...
Discussion in 'Off Topic Hot Rods & Customs' started by ALLDONE, Apr 23, 2025.
  1. ALLDONE
    ALLDONE
  2. ALLDONE
    ALLDONE
  3. DDDenny
    Here's a thought:eek:, why don't you go with some wheels more friendly to the main HAMB forum, then you can come back and play on both sides, many of us are welcome there.
    There's a lot more than Cragars and American five spokes to be had.
    ALLDONE likes this.
  4. RmK57
    RmK57
    I’d take it out at the transmission end, so it’s disabled. Plug the hole in the trans of co****.
    ALLDONE likes this.
  5. ALLDONE
    ALLDONE
    I'm not welcome there... kinda funny the way they come at me....I just post to hear me...and where its at... wife likes the wheels...her car so easy deal...
  6. RmK57
    RmK57
    The wheels look like Weld Pro Stars. If your wife likes them, then that’s the most important thing. Enjoy the car. I think it looks great.
    ALLDONE likes this.
  7. twenty8
    twenty8
    You have a real way with words....:D
  8. ALLDONE
    ALLDONE
    got an issue with this car, and I know the answer..... speedo cable making noise... looked under the dash... bird nest of wires every where... can't even see the cable... but gonna ask any way.... is there an old guy trick that I don't know to lube the cable??? probley the only way is to somehow get in there and take the four nuts out that hold the cluster on the dash??? then be able to un screw the cable from the speedo???
  9. ALLDONE
    ALLDONE
    changing the wheels is gonna require changing the rear end, the one thats in there is too wide... i have a v8 comet rear that about 56'' or so.. super hard to come by, so i was saving it for a 32 build...
  10. ALLDONE
    ALLDONE
    I remember as a young guy growing up...SPEEDOMETER SHOPS...
    YOU take your car to them... or the cable and they would fix it.... long gone???
  11. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    ALLDONE likes this.
  12. ALLDONE
    ALLDONE
    If I could take the cable out,... I could just lube it... speedo works and is dead on to radar.. but sounds like a ticking lifter.and makes the needle bounce
  13. 19Eddy30
    19Eddy30
    from VA
    Cut down , weld ends back on ,
    Can be done with out removing complete rear from vehicle,
    Jig not required as long as you take your time and think things through.
    May require a cut to fit axles
    ALLDONE likes this.
  14. ALLDONE
    ALLDONE
    I would just take the 60'' wide rear out and put the 56'' in...
  15. miker98038
    miker98038
    Last year or so I pulled the Speedo cable out from the dash end, lubed it, and put it back. Works fine. You just have to be patient and get your hand up there (unless the connection is frozen). Go gently thru the wires, it’s easier to knock a light bulb out than to get it back in. Look for cracked insulation while you’re there. If it original that can be a problem you need to address.
    ALLDONE likes this.
  16. ALLDONE
    ALLDONE
    thanks, went over to my sons..and I say.. back in the day... cars only had 12k warranty.. so you would stick your hand up in the dash and the un screw the speedo cable and drive it till you had to take it in for service....he saays... so are you asking me to un hook the speedo on the t bird.......yeah... I'm too old and fat to do it...he gets in there and says.. someome put a loop in it under the dash, so a minute latter,.. he had it out...i was able to pull it through the fire wall... I tried to pull the cable out but it was budging .. so I sprayed it with wd 40 pdf...figured I'd see about getting a new one , and see if taking the loop out fixed it first....so when I drove home... the cable was quiet... but the speedo still jumped a little...my son says they get a little fray on the mettal and it rubs ....??? we'll see.. but partial fixed now..
  17. swade41
    swade41
    from Buffalo,NY
    I've heard of people using dry graphite down the speedo cable, not sure how that would work with the wd40 though
    ALLDONE likes this.
  18. pprather
    pprather
    ALLDONE likes this.
  19. ALLDONE
    ALLDONE
    i'm thinking I should just get the whole cable... the one in there probley has issues ... and then it will be all new..
  20. pprather
    pprather
    Brand new should work.
    ALLDONE likes this.
  21. ALLDONE
    ALLDONE
    does anyone know if the port hole top is the same as the non??? and does the hard top fit all three years??
  22. pprather
    pprather
  23. ALLDONE
    ALLDONE
  24. jaracer
    jaracer
    Larger front sway bar and a rear sway bar make a big difference in the way they handle. Radial tires and the sway bars made a big difference in my 57 Bird. There was a guy in Oregon that made up front and rear sway bars for the little Birds, but I think he retired. His company was called Quickor.
    ALLDONE likes this.
  25. ALLDONE
    ALLDONE
    next mod will disc brakes..
  26. ALLDONE
    ALLDONE
    you would think... right... but got to thinking when I went to order the new one.....it's got a c4 trans.....wonder if the trans end is the same on the stock cable???? guess it has to go up on the lift to check....
  27. ALLDONE
    ALLDONE
    I used the quick dry lube wd with pdf....it's pretty much fixed.... but not perfect....
  28. ALLDONE
    ALLDONE
    then there's the driver window that won't go down..... I looked around on the web.... what a bucket of worms.... no wonder the guy didn't mess with it...
  29. ALLDONE
    ALLDONE
    so that was the start of the project...got the door panel off... cleaned the motor and got the old grease out... seems to be working,..gotta put that back together,.. the disc brake conversion showed up so it on the rack getting that done...
    my wife is gonna drive this so the brakes is a must...
  30. ALLDONE
    ALLDONE
    up date... got the disc brakes done... stops real nice....next problem... car gets hot setting at an idle.... did the towel test... it dropped like *****s ******* at the truck stop... look under the hood.... yep... flex fan.... so I order a new speed way fan...but while looking... 2 core radiator, cast intake manifold... points distributor... so ordered a new aluminum 4 core ...electronic dist. and aluminum manifold... no rest for the wicked....the angry bird needs attention....
