Hot Rods Annealing mig welds in order to planish?
Discussion in 'The Hokey Ass Message Board' started by Fortunateson, Oct 1, 2024.
  1. Fortunateson
    Fortunateson
    As the ***le states, is this a smart/dumb move? Any of you ever try it?
  2. oldiron 440
    oldiron 440
    It’s been years since I was hands on but MIG welds are different from TIG or a gas weld in that the weld is harder than the metal being welded. This means the weld is difficult to work often cracking, TIG or gas welding is what works.
    1932tub, Smiffy and hrm2k like this.
  3. goldmountain
    goldmountain
    What are you using to anneal with? If it is a torch, why not gas weld in the first place?
  4. I've seen people (with a name) who'll MIG weld things like part of a chop and then come back with a torch, get it red hot and proceed to hammer it out. I guess it worked but I'd argue why do 2 processes & introduce more heat into the panel than necessary. Fit up is priority #1 and then just TIG or Gas Weld the joint followed by the required hammer & dolly work to finish out the seam. Hope that kinda answers your question.
  5. ekimneirbo
    ekimneirbo
    from Brooks Ky
  6. SEAAIRE354
    SEAAIRE354
    I have tried it yet but plan to the next time I have a project that requires this type of work. It’s Esabs EZ grind mig wire. It’s softer and as the mane implys it grinds easier. I’m ***uming it would also hammer and dolly better but haven’t tried it. Will be following
    Poverty cap and hrm2k like this.
  7. Fortunateson
    Fortunateson
    Post results when you do please.
    Thanks for replies. It was just something I was thinking over as I recover....
    Did a search and found a similar thread I posted years ago. I think I’ll start practising my gas welding again...!
  8. Budget36
    Budget36
    Disclaimer: I’m no where near a professional, nor did I sleep in a HolidayInn express recently.
    But, I have done many patch panels with my MIG. **** ton of spot welds , jumping around. Waiting for the spots to cool to the touch before putting another next to it.
    Takes a long time.
    Once I’m done, angle grinder with the rubber pad thing and sanding disc. Slow and even and flush the spots to the metal. Verify no holes, or spot again.
    Should have little “weld bumps” on the back side of the seams.
    Once all airtight and sanded, I’ve never had an issue with some hammer and dolly work.
    I hit “off dolley” and not direct.
    But never even thought of annealing it, I thought that was for non-ferrous metals.
    Been fortunate to not have to use much filler this way.
    ekimneirbo and hrm2k like this.
  9. Fogger
    Fogger
    When my old friend Stan chopped my 3W he had a welder come to the shop, actually the backyard garage, to mig the top back on. The welder used the ESAB easy weld .023" and as he welded Stan would cool the weld with an air hose. When it was cool he hammered the weld on and off dolly. The finished top required very little filler, no more than a thin skim coat.. Both Stan and his welder friend were experts and the results showed. RIP Stan Beringhele
  10. Happydaze
    Happydaze
    @Fortunateson, are you thinking about softening the weld then planishing, ie without removing the excess material of the weld? I think you'll find if you do that once the weld is hammered flat there will be a ton of distortion as the excess material has to go somewhere.
    If you're thinking that annealing a ground flat weld might make planishing possible / easier / better I'd guess you could be right, or maybe not?
    Chris
  11. theHIGHLANDER
    theHIGHLANDER
    If you can get to both sides and have a willing friend with a mid level of skill, you can finish and "stretch" the weld as you go. 2 spots, gentle hammer n dolly while still red. You don't blast it into the next door neighbor's garage, just tap hard enough so the ball of weld resembles the head of a nail. You only have to tap it 3-5 times if that. And if you can do that with EZ-Grind all the better, yes it's softer. Done right and well you can do a zero mud metal finished seam. It ****s a little, it ain't easy, but it ain't hard once you get your mojo on. I hope you can "see it" just how I spelled it out. Why do it? While it's red and cooling you're stretching the weld vs how it will contract and warp the panel. Lemme know if this all makes sense.
  12. Mike VV
    Mike VV
    from SoCal
    Have you...say looked through the ...INTERNET..?
    HOURS of reading...already in print. Without having to rewrite it all !
    Mike
  13. Smiffy
    Smiffy
    Trying to anneal a mig weld is like trying to anneal a piece of gravel. Hard and unflinching. Seriously suggest you either tig weld or gas weld if you want to anneal your welds.
    camer2 likes this.
  14. rockable
    rockable
    I am not an expert but I recall reading the carbon in C25 welding gas is added to the MIG weld and that additional carbon is one factor in making it harder. As was mentioned, the additional heat will likely cause additional distortion. If you just weld it gradually as is mentioned, you will have minimal distortion, most of which can be planished out. If you truly want to metal finish it, and it's a lot of work, learn to TIG.
    alanp561 and Bangingoldtin like this.
  15. Fortunateson
    Fortunateson
    All interesting replies so thanks! When I mig I do the tacks about 3” or so apart, take a cutoff wheel and grind down what’s proud, and then do the
    whole process over again. I may buy some easy grind wire if I can find some...
    When I Metal finish it I use a hammer and ONLY tap (they should be called body tapperss not hammers!).
    Like I said as I recover I’ve been doing some thinking and this popped into my head. And I guess it’s time to try to improve my gas welding...I’ll be using a Dillon/Henrob/Cobra to have with its tiny focused flame. Maybe that will help me from creating “ventilation holes”! LOL
    EXIT: I forgot to say that while the tacos are still hot/warm I try to tap them flat...
    alanp561 and G-son like this.
  16. Scott079
    Scott079
    from Canada
    I only do mig right now, argon is way too expensive for how much I would use a tig at home.
    But I try to leave a cutoff wheel size gap for mig instead of ****ing the filler piece tight. Then I do 2 or 3 tacks then hammer and dolly right away while they’re still warm. It does take a while, but then it’s also minimal grinding and there is still some room for the weld to stretch within the gap.
    jazz1 and alanp561 like this.
  17. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I have heard the same about the EZ grind wire. Supposed to be very nice to work with.
  18. alanp561
    alanp561
    I believe that without planishing, the shrinkage from the weld cooling will distort the parent metal even more than with planishing.
    Happydaze likes this.
  19. Fortunateson
    Fortunateson
    alanp561 likes this.
  20. nrgwizard
    nrgwizard
    from Minn. uSA
    Highlander, the comments you made are easy to envision.
    Marcus...
  21. Fortunateson
    Fortunateson
    Makes perfect sense. Thanks!
  22. I’ve done similar. Hammer and dolly as I weld.
    I prefer to use a small ball peen hammer for this.
  23. mickeyc
    mickeyc
    I have been unable to find the easy grind wire for some time.
    Saw reference to it a few times, and asked at a couple of local weld
    supply places. They all had never heard of the product.
  24. rockable
    rockable
    https://esab.com/us/nam_en/locator/
