another 235 chevy question
Discussion in 'The Hokey Ass Message Board' started by ken arms, Feb 29, 2012.
  1. ken arms
    ken arms
    I am building an early 235 (1953) for a friend, we want to pull his 216 out of his 52 pickup and use the 235. The 235 has no bellhousing or flywheel. Can anyone tell me if we can use his original 216 bell, flywheel, press plate/clutch? Thanks Ken
  2. squirrel
    yeah, you can use all the original stuff. Beware that the flywheel for a car that came with a 6 volt system (54 and earlier) will only work with the 6 volt starter. Although you can run the 6v starter on 12 volts.
  3. 6inarow
    6inarow
    Squirrel, why did you change your avatar?? I vote to use the old one of your 55. We can start a poll on this issue if need be
  4. cederholm
    cederholm
    HA! That confused me too. I was thinking, boy that guys sounds like Squirrel...
  5. squirrel
    just messin with ya
  6. Snarl
    Snarl
    yes.
  7. Curt B
    Curt B
    Keep in mind that the timing ball on a 216 flywheel is located 5 degrees before TDC and is at 2 degrees after on later 235/261's. This parts combo means a timing light won't work but a vacuum gauge will do.
  8. jcmarz
    jcmarz
    from Chino, Ca
    I have the orginal 51 216 in my truck and I don't have a timing ball on my flywheel just two letters and I found out that that timing mark is between those two letters. Like everyone said, the 216 parts will work on the 235. That's the beauty of a Chevy. Interchangeability.
  9. ken arms
    ken arms
    Thanks guys, I thought it would all match but good to be sure, once the new engine is done we want the swap to go fast, my garage is small with many projects! Ken
