Another 55 Straight Axle Chevy Gasser build.
Discussion in 'The Hokey Ass Message Board' started by Baron, Nov 28, 2007.
  1. Baron
    Baron
    I have posted a few pics on a couple other threads. Figure I'd start my own. This is my winter project, and with any luck, it will be out this spring. Hopefully this will inspire a few here who love the 60's gasser look. A picture is worth a 1000 words....
    Stock frame
    2 x 4 tubing subframe
    2 1/2 inch altered wheelbase
    392 mounts fabbed and front mounted steering box
    kiwijeff likes this.
  2. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Looking Good Baron..........nice job, the only thing I would do ... is fab up a alternator bracket lower, down towards the crank...........That would really clean up the engines apearance up top..........Good choice for an engine..Have fun Littleman, they make smaller alternators.but it all looks great..
    Baron likes this.
  3. Hotrod F-1
    Hotrod F-1
    from OK
    Great start you have! I'm sure it will be just as great and a fun ride when you are done. :cool:
  4. jackal396
    jackal396
    The car is looking really good, some excellent 55 chevys on the site.
    jp
  5. Dirty2
    Dirty2
    Very nice !!!
  6. Screenz
    Screenz
    from Texas city
    Nice very nice
  7. Wow, I especially like the skull hanging from the mirror
  8. Louie S.
    Louie S.
    Nice work! Cool engine:cool:
  9. Terry
    Terry
    Looks radical! Very nice work!
  10. A 31 MO FO
    A 31 MO FO
    from D/FW
    Dam good start, now I need to get mine going. Keep it up!!!!
  11. Blown 61
    Blown 61
    Way cool, but you got them pulleys flip flopped.:D
  12. Gee whiz.....liked the project from the title.....when it got to the engine.....over the top.
    This is gonna be a cool build/car when done.
    Keep us posted
    Skot
  13. Baron
    Baron
    Picking away at it. Steering is almost done. Radiused the rear wheelwells for the Hoosier 315/60R-15s Drag radials will just peek outside the quarters(mounted on 10 inch Cragars).
    hotrodtodd1960 likes this.
  14. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    WOW, nice job, keep it going. Gary
  15. way cool i always loved gassers , your straight axle 55 looks great
  16. The Shocker
    The Shocker
    Nice job indeed my firend...
  17. Mercury Kid
    Mercury Kid
    Thank you so much for not putting a SBC in it! I agree though, you have those pulleys on upside down. Bitchin car!
  18. Ford Freak
    Ford Freak
  19. Baron
    Baron
    Thanks! The rear wheel wells look better filled up with the
    315/60R-15 Hoosier DOT Drag radials on 10" Cragars.
    Finished the steering today so now it's a "roller" once again. Made up the upper front shock mounts and will do the lowers this coming week. Have a set of Comp Eng adjustable frt shocks(90-10 to 60-40). That will pretty much finish the front suspension and then I'll start on the rear. Going with a 9 inch Ford, mounted to the rear springs with a lower pivot /perch set up in conjunction with the S&W Race Cars 42" long " Gasser Ladder bars".
  20. AnimalAin
    AnimalAin
    Neat car. A bold combination of interesting components artfully arranged. Keep us advised as you progress.
  21. Baron
    Baron
    Radiator support and radiator mount are finished.Six bolts,disconnect the radiator hoses and the nose came be removed(keeping it simple). There were a couple of small spots on the floors that needed a little attention and I finished that today(a job that has to be done, but not much fun...) Next project will be welding in new rear mounts for the front spring. Going to raise the car about 1 1/2 inches at the rear mount. Then finish the lower shock mounts and install the CE 90/10 adjustable frt shocks. Once that is finished,I will turn my attention to the back of the car, installing the 9" Ford and S&W ladder/Gasser bars. Now that's all fun stuff to do :)
  22. The Shocker
    The Shocker
    That sucker looks mean as hell in that last pic.My old man had a 55 150 in 1961 that he swapped a 392 into out of a 300C.I have always had a soft spot for these kind of motor swaps .More power to you my friend...
  23. kurts49plym
    kurts49plym
    from IL
    Real bad machine!
  24. dragrcr50
    dragrcr50
    I know a well built gasser when I see one,. and that is a very well built 55, congrats. Its gonna be a killer car.........
  25. senior fried
    senior fried
    Nice build, Your going to be a popular guy , racing against all those big block chevy guys. Good luck..
  26. dirty mikey
    dirty mikey
    from chicago IL
  27. A 31 MO FO
    A 31 MO FO
    from D/FW
    Looking good! More PIC"S PLEASE.
  28. JohnT
    JohnT
    How did you bullnose the front of the frame rails?
    Nice work.
  29. drofdar
    drofdar
    from Fresno Ca
    Here's mine. Hope to get it running this spring. Ok, it's just a 454. ;)
  30. Baron
    Baron
    Thanks guys.
    John. All I did was piecut the bottom of the tubing to give them the taper, cut/round the end of the tubing to the shape I wanted , and bent and welded some 1/8" x 2"steel to cap the ends.I may still reshape them to make them a little rounder before I paint the chassis(also going to add the mounts for the Moon tank).
    Just got back from vacation. Can't wait to get back to work on it.
