Another axle set-up question
Discussion in 'The Hokey Ass Message Board' started by model-a-fan, Feb 27, 2009.
  1. model-a-fan
    model-a-fan
    from Kentucky
    Well, thanks to your help, I've almost gotten my axle together. I have one last question.
    I'm running the forged Speedway dropped steering arms on my '37 spindles. The issue is the won't fully clear the bottom of the axle. ('36) What would be the best way to remedy this probelm? Clearance the axle or the steering arm? I would estimate that I would have to remove about 1/4" of material to eliminate the touch off. Is their any safety issues with doing either?
    TIA!
  2. Rocky
    Rocky
    Classified Editor
    Yeah, there's safety issues with removing metal from both parts. The old tried and true way of gaining clearance is to simply heat and bend the arms down a bit and then heat and bend the ends of them back parallel with the ground.
  3. QMOTOX
    QMOTOX
    from STL, MO
    The way to solve it is to send those arms back to Speedway and order some new arms from Compe***ion Engineering. The arms from CE don't wrap around the kingpins like the ones you have now.
    I don't think I'd remove a 1/4" of material from either piece when you can get an arm that won't require any modification.
  4. QMOTOX
    QMOTOX
    from STL, MO
  5. model-a-fan
    model-a-fan
    from Kentucky
    OK that's what I'll do. I didn't lke the idea of removing material either.
  6. Fogger
    Fogger
    You're doing the right thing buying the Ch***is Engineering steering arms. Safety is no accident, get the best American made parts you can find. The FOGGER
  7. I ran into the same problem om my never ending roadster project when I found a really nice undropped, chromed '34 axle at a swap meet for $15. I hate the flat bent arms with heim joints so the CE parts are the answer.
  8. model-a-fan
    model-a-fan
    from Kentucky
    Yeah, the flat ones do look cheesy.
