Technical Another bad distributor...........
Discussion in 'Traditional Hot Rods' started by vetteson, May 20, 2022.
  1. vetteson
    vetteson
    I've had terrible luck with distributors, anyway I have a three year old A-Team Performance distributor in my '56 Corvette. Recently while driving the engine just quit. No cough, no sputter. Engine would crank but no start. It was getting plenty of fuel. Changed the external coil in the field but no luck. Wiring looked ok and everything was still connected. Once home I checked wiring again and began running tests of the coil/distributor circuit. Then I thought maybe a circuit in my 30 year old ignition switch had gone away so I bought s new one. No change. I am apparently getting 12 V at the coil and about 8 V to the distributor cap. Next is the distributor. Has anyone had similar experience(s) with this unit? Do they simply fail?
  2. PhilA
    PhilA
    Yup, that is a failure mode of harsh condition electronics.
    hrm2k and jaracer like this.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No idea. Just bought another o.e. cast iron point distributor the other day because I like them so much.
  4. sloppy jalopies
    sloppy jalopies
    bought a $75.00 , 289/302 points dist., bushings were so sloppy i put it in the make a rodrun trophy pile...
    i grab the stockers at swappers when cheap and not to sloppy... then add pertronics...
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Any slop is a p*** for me.
    427 sleeper likes this.
  6. 427 sleeper
    427 sleeper
    Never had a problem like that with a Delco single or dual point distributor using the points and condenser. Granted some of the condenser's are questionable these day's but they won't leave you stranded.
    Truckedup, olscrounger and Moriarity like this.
  7. X38
    X38
    Had to google A-Team performance distributors. Found out they are sold solely via Southwest Performance Parts. Then there's the Southwest Performance Parts address:
    177 Huntington Ave,
    Floor 17
    Boston, MA 02115
    I'd be joining the dots on this one and suggest that those distributors are made you-know-where, very cheaply and not very well.
    A couple of reviews:
    • This worked for 5 min .they sent me a new part .had it installed still would not work .JUNK .I bought a lot of products off line never had a problem .threw it in the trash.
    • Junk. The magnets weren’t even tight and when I started my motor CRACK! Took the cam gear out. The magnets in the distributor meshed.
    These reviews were one after the other, I didn't need to go cherry picking.
  8. blowby
    blowby
    from Nicasio Ca
    Driver50x likes this.
  9. Mr48chev
    I've never had a cast iron Delco that was actually bad. I've had a few aluminum ones that had worn bushings on the shaft.
    I'm thinking that some of those cheaper aftermarket electronic distributors should be viewed as pretty much disposable. When it's time for a cap and rotor it is probably time to replace the whole thing.
  10. X38
    X38
    I think they mean Hall effect.
    jaracer, Toms Dogs, joel and 2 others like this.
  11. vtwhead
    vtwhead
    Get rid of it, best advice given.
  12. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>JUNK>>>>hese reviews were one after the other, I didn't need to go cherry picking.>>>>
    This is so true. But only If you pick the 1-star reviews, 8^)
    AHotRod likes this.
  13. blowby
    blowby
    from Nicasio Ca
    Yes of course, but if the A-Team can't get that right in their ad what does it say about their involvement in the product?
    An electronics engineer with experience in components, diodes, transistors etc., told me there are big differences in the quality of those components, which of course all come from overseas. Mostly manifested in their longevity.
    rockable and AHotRod like this.
  14. 61cad
    61cad
    Magneto
    it will cure your ill’s
    Hollywood-East and 427 sleeper like this.
  15. Oilguy
    Oilguy
    I had a new Delco condenser leave me stranded recently. Engine would run, then die, then run again.
    jimmy six likes this.
  16. wraymen
    wraymen
    “Bogus product reviews are an epidemic, according to Saoud Khalifah, founder and CEO of Fakespot, a site that ferrets out fake reviews. Khalifah says many product reviews are not real — and he has the data to prove it.
    Companies constantly plant positive reviews of their own products and sully compe***ors’ products with negative reviews,” he says. As a result, many of the ratings you read online aren’t credible. For example, up to 70 percent of the reviews on Amazon are not real, he says.“
    A clip from a Forbes article from a few years ago. I have a lot more faith in a Hamb review than one from the site that’s selling the product.
  17. vetteson
    vetteson
    Ok, follow up, I would not be surprised about trouble prone distributors made in Asia. And here I've got another one. Maybe it's not the new distributor but with everything set up the engine starts and runs but only with vacuum disconnected! If I try to connect the tube, the engine immediately stumbles, pops and dies.
  18. doyoulikesleds
    doyoulikesleds
    was a common failure on hei distridutors when the wires from the pickup to the modual
    lostmind and Algoma56 like this.
  19. hepme
    hepme
    True. I've used the Delco's ever since i started in this fool hobby--never a failure of any, including multiple dual point types. Converted the duals to Pertronix for the look and they were reliable also.
  20. vetteson
    vetteson
    Ok, has any one had a vacuum advance disfunction or failure in an aftermarket "ready to run" electronic distributor?
  21. Dan Timberlake
    Dan Timberlake
    Wasn't the "chip shortage" from supply problems with the well proven perfected manufacturing methods that had evolved to producing near aerospace quality electronic components for automotive OEMs ?
    Compared to the early off topic days (late 70s to mid 80s Duraspark and HEI) modern car electronics are very robust, despite being crazy complicated.
  22. Illustrious Hector
    Illustrious Hector
    I've put Pertronics in my Olds engine and later installed them in a 401 Buick, both stock GM dizzys, both well "worn"
    They work flawlessly, I will be putting one in my other Buick, as I have no confidence in anything made in China.
    Rather than read reviews planted by the website selling this junk, I would seek out the first hand knowledge of those on these forums.
    Truckdoctor Andy likes this.
  23. X38
    X38
    Define what you mean by 'aftermarket.'
    If distributors made you-know-where use the same 'rubber' they use for brake booster diaphragms and tie rod end dust boots, I would not trust the vacuum advance diaphragm. (A****st other things:rolleyes:)
  24. rockable
    rockable
    Pertronix and HEI distributors require 2 things. The first is an absolutely great ground. I think it is less than .2 ohm as measured at the distributor case and the battery negative post. The second is an alternator that is "up to snuff". If one of the diodes is leaking AC current, you will kill solid state distributor.
    I had 2 vehicles that had that problem. Both had older alternators and, once replaced, the problems went away.
    ffr1222k likes this.
  25. Points and Condenser, one set in the dist. and one set in the glove box will get you there and home again.
    Illustrious Hector and Moriarity like this.
  26. hrm2k
    hrm2k
    I put one of Southwest Performance HEI’s in a Friend of mine’s O/T Rambler. It ran for less than 2 hours and quit. I pulled module out and replaced it with a NAPA unit. Problem solved. I will never use Southwest Performance products again.
    NoSurf likes this.
  27. 1971BB427
    1971BB427
    from Oregon
    Is this A-Team distributor an electronic replacement distributor, and not a modern version of an old points distributor? If so, do you still have a ballast resistor ahead of the coil that's dropping voltage down? The details you gave originally sure sound like the kind of voltage drop I'd expect to see across a ballast resistor. And most electronic distributors, or conversion kits don't work with the ballast resistor inline, except for the Accel 2010ACC conversion that requires the ballast resistor.
    ffr1222k and BoilermakerDave like this.
  28. dirt t
    dirt t
    Desoto291Hemi likes this.
  29. nutter_street_rodder
    from Nevis MN
    Had a buddy in 1969 walk into a Chevy dealership and ask the parts guy to order an electronic distributor for his 67 Vette (it was a plug-in). The parts guy asked why, and told him " if you are in the middle of no where and it fails you're done until you can find a radio tv repairman" He then went on to say that "you can file a set of Ford points to get home in an emergency"..... he left the dealership without ordering the "fancy" distrib!
    427 sleeper and rust runner like this.
  30. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Someone once asked me why marine engines hung onto points distributors long after the automotive industry had moved on from them; I told him that it was probably because it's much harder to walk home from the middle of a lake.
