another barn find..."not worth the effort"
Discussion in 'The Hokey Ass Message Board' started by hillbilly4008, Sep 22, 2010.
  1. Terrible Tom
    Terrible Tom
    Ignore the negatives. People like to blow. I think you did very well. That body looks solid. Get it up on some wheels and it'll look a lot better.
    Tom
  2. plym_46
    plym_46
    from central NY
    most of the 27-30 Chryslers, and desotos had 3 hinges on the rear door. I notice your's only has 2. What is the engine number (same place as on your desoto)
  3. hillbilly4008
    hillbilly4008
    from Rome NY
    Greg, engine # CJ6609. Briggs body #390-3947
    haha, I just found a Texaco service sticker on the A pillar, and part of a fruit crate that reads "Arizona Quality Melons" Thats goin on the wall.
    EDIT: #CJ****x shows it to be a 1930. Please correct me if i'm wrong, but thats what AACA shows.
  4. el Scotto
    el Scotto
    from Tracy, CA
    Very cool, I like it! The beginning of hot rod that has some cl***! :)
    I like the fenders, too! Gonna run 'em?
  5. My book says "The Series CJ was a line of all-new, downsized models bearing the Chrysler name. This series was actually a 1930 1/2 series and was introduced in February of 1930." The engine number is fairly early, they began CJ1001 and ended CJ24494. Production is 20,748 for the 4-door sedan. There also were a roadster, touring, coupe and convertible coupe in the CJ line.
    When it comes to parts, this book notes the CJ carried over to 1931 "with little change, except that the cowl lamps were now mounted on the suricingle and new special type spring shackles were introduced." ... what the hell is a suricingle?
    Wheelbase is 109 inches, the same as DeSoto series K and Dodge DD, so you may have some options if finding the right grille and hood proves difficult. Some of the listings show 109.75 inches, some just 109 ('29 DeSoto K and the Plymouths have the extra 3/4 inch).
  6. plym_46
    plym_46
    from central NY
    ^^^^ a suricingle refers to the belt that goes around a horse to secure the saddle or pack. It can also refer to the belt or rope the retain a c***osk. Think the rope around Friar Tucks outer garment. Looks like ther is a stainless or cast piece that seperates the hood from the cowl, in the pic of the blue car below the cowl lights are attached to that tather than to the cowl sheet metal.
    The specs for the CJ are;
    wheelbase109, curb weight 2390/2695, tire size 5.00x19, wheel bolt pattern 5 x 4.5. valve location In Block, bore and stroke 3 1/8 x 4 1/4, disp 195.6, CR 5.20, HP 62 @ 3200
    looks like it may be able to run on kerosene....
    http://forums.aaca.org/f169/1931-chrysler-cj-6-info-needed-298028.html
  7. plym_46
    plym_46
    from central NY
    Im guessing the suricincle is the black highlighted body stamping. ( guess incorrectly, see above)
  8. plym_46
    plym_46
    from central NY
  9. hillbilly4008
    hillbilly4008
    from Rome NY
    So going by the cowl lamps I'd swear that this is a '30. Same as the Red pic above. Note the hole above the beltline on the cowl.
    I am going to do some measuring on the rear axle. Fingers crossed a Jeep Cherokee may fit nicely. Where could I find some front hubs? I am going to ***ume that the drums are rivited to the hubs like on my DeSoto.
    Also, where is the best online site for this car?
  10. Too bad you can't sneak off to Hershey this weekend, I bet you'd find what you need there. I told Mark to have a look and if he sees anything maybe he can p*** on the seller's contact info -
    In fact, somewhere up there he has a vintage Chrysler axle that's complete to the hubcaps, I'm not sure what year it is. I remember helping unload it a few years ago.
    Or you could try swapping in something like an A100 or Econoline front axle that's still an I-beam and will look right but be a little easier to find parts for.
    I'd say with the numbers it's pretty safe to conclude it's a '30. State won't know the difference when you do the MV51 anyways. No tag anywhere on the dash with a body serial number?
  11. bgbdlinc
    bgbdlinc
    ...here's mine when I got it....1930 - 3 hinge rear doors as mentioned with a 3" chop, bad frame, rotten wood, but a few interesting details like side cowl vents, 'arched' windows,
    ...and as it is now (er, planned)....
  12. lintmann
    lintmann
    from calgary
    Neat find. Does it have hydraulic brakes? I think I see a wheel cylinder on the front hub there.....
  13. Rebel 1
    Rebel 1
  14. Tony
    Tony
    Cool find Joe! Glad you were able to work something out with the previous owner.
    I'm not a 4 door guy, but i actually like the lines of it. It'll make a fun project and family hot rod!
    Tony
    ps: the resto on your old 63 will be starting within a week or so :D
  15. chopper526
    chopper526
    from Phila., PA
    I like it, good luck!!
  16. budd
    budd
    heres my friends 30 chrysler, stock, this is a big day new tires and refinished wheels, over the winter i'm going to re-ring it, add some driving lights and two fender mount spares.
  17. hillbilly4008
    hillbilly4008
    from Rome NY
    Yes, it had hydraulic brakes all the way around. Another cool feature that I noticed today is that the quarter gl*** rolls down.
  18. biggest picture ever wow???
    HOW DID YOU DO THIS ?
    I HAD TO SCROLL INTO THE NEXT ROOM TO SEE ALL OF IT
  19. hillbilly4008
    hillbilly4008
    from Rome NY
    Yeah, but look at the detail!
  20. Okie Pete
    Okie Pete
    Hillbilly looks good alot better than the rust i drag home.
  21. plym_46
    plym_46
    from central NY
    Devil is in the details, so why not get the big picture.
    Whaddya gonna use for power, gonna try to get that motor to spin over???
    Just copied it and pasted it from another source, wasn't that big o the oother site.
  22. milwscruffy
    milwscruffy
    A friends 1929 for inspiration.
  23. hillbilly4008
    hillbilly4008
    from Rome NY
    I have no idea what I am going to use for an engine. I'd love to drop another flat head six in there, a 265 done up with all the extras would be nice backed by a top loader of some sort.
    The block that is in there now I was just gonna try and sell it for a few bucks. I'm sure someone out there could use it. Theres not alot there just block,motor mount plate, crank, pistons, flywheel, and bell housing.
  24. brian55lvr
    brian55lvr
    from ma
  25. MrModelT
    MrModelT
    Great Find!
    Judging from door handle placement, and the body lines, it looks like a 1929 Series 65 sedan. There were a few differences in 1930 that this car just doesn't have.
  26. billylo
    billylo
    Man I thought I was persistent.....Congrats. Not everyone is lucky enough to find a 32 Ford. Just build it with a bunch of details and everyone will love it.
  27. strelnik
    strelnik
    from Michigan
    Now you know why God makes people die...
  28. If you weren't clear across the continent I have six from a '50 De Soto...
  29. hillbilly4008
    hillbilly4008
    from Rome NY
    I got a tip on an estate sale this sunday. There is a '50 Desoto there. To bad im tapped out.
