I have 2 bbc core motors. I was told they are 454 truck motors,but I cant find the code or casting numbers in my limited library. On the left rear of motor #1 the casting # is 361959. On the pad in front its stamped cof331056. Motor #2 the casting # is 389628,and the front pad is stamped ce556520.They both have small oval port heads and Q-jet intakes and carbs that I'm not going to use. My plan is to use the best block,crank,and rods and go from there.Can anyone look these up?
Big Block Casting numbers <TABLE cellSpacing=0 cellPadding=0 align=center><COLGROUP><COL width=136><COL width=94><COL width=89><COL width=354><TBODY><TR height=20><TD height=20 width=180>Casting Number </TD><TD width=94>Years </TD><TD width=89>CID </TD><TD width=354>Comments </TD></TR><TR height=17><TD height=17>340220 </TD><TD>72-76 </TD><TD>427 </TD><TD>Truck Tall deck </TD></TR><TR height=17><TD height=17>345014 </TD><TD>74-86 </TD><TD>454 </TD><TD>Truck </TD></TR><TR height=17><TD height=17>346236 </TD><TD>74-76 </TD><TD>454 </TD><TD>2-bolt </TD></TR><TR height=17><TD height=17>359070 </TD><TD>74-90 </TD><TD>454 </TD><TD>Truck </TD></TR><TR height=17><TD height=17>361959 </TD><TD>73-85 </TD><TD>454 </TD><TD>Car & Truck </TD></TR><TR height=17><TD height=17>364776 </TD><TD>68-84 </TD><TD>427 </TD><TD>Truck Tall deck </TD></TR><TR height=17><TD height=17>364779 </TD><TD>68-88 </TD><TD>366 </TD><TD>Truck Tall deck </TD></TR><TR height=17><TD height=17>399204 </TD><TD>70-71 </TD><TD>509 </TD><TD>4-Bolt Aluminum Can-AM </TD></TR><TR height=17><TD height=17>399289 </TD><TD>73-79 </TD><TD>454 </TD><TD>2-bolt </TD></TR><TR height=17><TD height=17>399293 </TD><TD>77-78 </TD><TD>366 </TD><TD>Truck </TD></TR><TR height=17><TD height=17>473478 </TD><TD>68-84 </TD><TD>427 </TD><TD>Truck Tall deck </TD></TR><TR height=17><TD height=17>3716362 </TD><TD> </TD><TD>396 </TD><TD> </TD></TR><TR height=17><TD height=17>3732755 </TD><TD>59-61 </TD><TD>348 </TD><TD> </TD></TR><TR height=17><TD height=17>3732811 </TD><TD>58 </TD><TD>348 </TD><TD> </TD></TR><TR height=17><TD height=17>3751872 </TD><TD>58 </TD><TD>348 </TD><TD> </TD></TR><TR height=17><TD height=17>3755011 </TD><TD>59-61 </TD><TD>348 </TD><TD> </TD></TR><TR height=17><TD height=17>3771705 </TD><TD>59-61 </TD><TD>348 </TD><TD> </TD></TR><TR height=17><TD height=17>3782012 </TD><TD>58-61 </TD><TD>348 </TD><TD> </TD></TR><TR height=17><TD height=17>3782870 </TD><TD>68-76 </TD><TD>427 </TD><TD>Truck Tall deck </TD></TR><TR height=17><TD height=17>3788068 </TD><TD>62 </TD><TD>409 </TD><TD> </TD></TR><TR height=17><TD height=17>3795623 </TD><TD>61 </TD><TD>409 </TD><TD> </TD></TR><TR height=17><TD height=17>3798962 </TD><TD>62-65 </TD><TD>348 </TD><TD>Truck </TD></TR><TR height=17><TD height=17>3815707 </TD><TD>58-61 </TD><TD>348 </TD><TD> </TD></TR><TR height=17><TD height=17>3824553 </TD><TD>66-67 </TD><TD>366 </TD><TD>Truck </TD></TR><TR height=17><TD height=17>3830814 </TD><TD>63 </TD><TD>409 </TD><TD> </TD></TR><TR height=17><TD height=17>3839752 </TD><TD>62-63 </TD><TD>409 </TD><TD> </TD></TR><TR height=17><TD height=17>3839754 </TD><TD>65 </TD><TD>409 </TD><TD> </TD></TR><TR height=17><TD height=17>3844422 </TD><TD>64 </TD><TD>409 </TD><TD> </TD></TR><TR height=17><TD height=17>3855961 </TD><TD>66-67 </TD><TD>396 </TD><TD>2-bolt </TD></TR><TR height=17><TD height=17>3855962 </TD><TD>65-66 </TD><TD>396 </TD><TD>4-Bolt </TD></TR><TR height=17><TD height=17>3855977 </TD><TD>65-67 </TD><TD>366 </TD><TD>Truck Tall deck </TD></TR><TR height=17><TD height=17>3857651 </TD><TD> </TD><TD>409 </TD><TD>Marine </TD></TR><TR height=17><TD height=17>3857655 </TD><TD>62-65 </TD><TD>348 </TD><TD>Truck </TD></TR><TR height=17><TD height=17>3857656 </TD><TD>65 </TD><TD>409 </TD><TD> </TD></TR><TR height=17><TD height=17>3857658 </TD><TD> </TD><TD>409 </TD><TD>Marine </TD></TR><TR height=17><TD height=17>3860386 </TD><TD>62-64 </TD><TD>409 </TD><TD> </TD></TR><TR height=17><TD height=17>3860387 </TD><TD>58 </TD><TD>348 </TD><TD> </TD></TR><TR height=17><TD height=17>3869942 </TD><TD>66-67 </TD><TD>427 </TD><TD>2 & 4-Bolt </TD></TR><TR height=17><TD height=17>3873858 </TD><TD>66 </TD><TD>396 </TD><TD>4-Bolt </TD></TR><TR height=17><TD height=17>3902406 </TD><TD>67 </TD><TD>396 </TD><TD>2 & 4-Bolt </TD></TR><TR height=17><TD height=17>3902466 </TD><TD>65-67 </TD><TD>396 </TD><TD> </TD></TR><TR height=17><TD height=17>3904351 </TD><TD>67 </TD><TD>427 </TD><TD>2 & 4-Bolt </TD></TR><TR height=17><TD height=17>3904354 </TD><TD>66-67 </TD><TD>366 </TD><TD>Truck Tall deck </TD></TR><TR height=17><TD height=17>3916319 </TD><TD>68-85 </TD><TD>366 </TD><TD>Truck Tall deck </TD></TR><TR height=17><TD height=17>3916321 </TD><TD>68 </TD><TD>427 </TD><TD>2 & 4-Bolt </TD></TR><TR height=17><TD height=17>3916323 </TD><TD>68 </TD><TD>396 </TD><TD>2 & 4-Bolt </TD></TR><TR height=17><TD height=17>3918319 </TD><TD>66-70 </TD><TD>366 </TD><TD>Truck </TD></TR><TR height=17><TD height=17>3925521 </TD><TD>68-85 </TD><TD>366 </TD><TD>Truck Tall deck </TD></TR><TR height=17><TD height=17>3935439 </TD><TD>68-69 </TD><TD>427 </TD><TD>2 & 4-Bolt </TD></TR><TR height=17><TD height=17>3935440 </TD><TD>68-69 </TD><TD>396 </TD><TD>2 & 4-Bolt </TD></TR><TR height=17><TD height=17>3937724 </TD><TD>68-85 </TD><TD>366 </TD><TD>Truck Tall deck </TD></TR><TR height=17><TD height=17>3937726 </TD><TD>68-84 </TD><TD>427 </TD><TD>Truck Tall deck </TD></TR><TR height=17><TD height=17>3946052 </TD><TD>69 </TD><TD>427 </TD><TD>ZL-I Aluminum 4-Bolt </TD></TR><TR height=17><TD height=17>3946053 </TD><TD>97 </TD><TD>427 </TD><TD>ZL-I Aluminum 4-Bolt 2nd design </TD></TR><TR height=17><TD height=17>3955270 </TD><TD>69 </TD><TD>427 </TD><TD>2 & 4-Bolt </TD></TR><TR height=17><TD height=17>3955272 </TD><TD>69 </TD><TD>396/402 </TD><TD>2 & 4-Bolt </TD></TR><TR height=17><TD height=17>3955274 </TD><TD>68-85 </TD><TD>366 </TD><TD>Truck Tall deck </TD></TR><TR height=17><TD height=17>3955276 </TD><TD>68-84 </TD><TD>427 </TD><TD>Truck Tall deck </TD></TR><TR height=17><TD height=17>3963512 </TD><TD>69-71 </TD><TD>427/454 </TD><TD>2 & 4-Bolt COPO </TD></TR><TR height=17><TD height=17>3963513 </TD><TD>73-76 </TD><TD>454 </TD><TD> </TD></TR><TR height=17><TD height=17>3965440 </TD><TD>68-69 </TD><TD>396 </TD><TD> </TD></TR><TR height=17><TD height=17>3965449 </TD><TD>68-72 </TD><TD>396 </TD><TD> </TD></TR><TR height=17><TD height=17>3969852 </TD><TD>68-84 </TD><TD>366 </TD><TD>Truck </TD></TR><TR height=17><TD height=17>3969854 </TD><TD>69-72 </TD><TD>396/402/454 </TD><TD>2 & 4-Bolt </TD></TR><TR height=17><TD height=17>3969858 </TD><TD>68-84 </TD><TD>427 </TD><TD>Truck Tall deck </TD></TR><TR height=17><TD height=17>3995623 </TD><TD>61 </TD><TD>409 </TD><TD> </TD></TR><TR height=17><TD height=17>3999289 </TD><TD>72-78 </TD><TD>454 </TD><TD>Car & Truck 2-Bolt </TD></TR><TR height=17><TD height=17>3999290 </TD><TD>72 </TD><TD>402 </TD><TD>2-bolt </TD></TR><TR height=17><TD height=17>3999293 </TD><TD>68-85 </TD><TD>366 </TD><TD>Truck Tall deck </TD></TR><TR height=17><TD height=17>3999294 </TD><TD>68-84 </TD><TD>427 </TD><TD>Truck Tall deck </TD></TR><TR height=17><TD height=17>6272176 </TD><TD>68-76 </TD><TD>366 </TD><TD>Truck </TD></TR><TR height=17><TD height=17>6272177 </TD><TD>72 </TD><TD>402 </TD><TD>2-bolt </TD></TR><TR height=17><TD height=17>6272181 </TD><TD>73-76 </TD><TD>427 </TD><TD>Truck </TD></TR><TR height=17><TD height=17>10051107 </TD><TD> </TD><TD>454 </TD><TD>4-Bolt Bowtie IV Short deck </TD></TR><TR height=17><TD height=17>10068286 </TD><TD>90-91 </TD><TD>454 </TD><TD>4-Bolt IV Short deck </TD></TR><TR height=17><TD height=17>10069284 </TD><TD> </TD><TD>427 </TD><TD>Truck </TD></TR><TR height=17><TD height=17>10114182 </TD><TD>91-95 </TD><TD>454 </TD><TD>4-Bolt Gen-5 </TD></TR><TR height=17><TD height=17>10114183 </TD><TD>91-95 </TD><TD>366 </TD><TD>Truck Gen-5 </TD></TR><TR height=17><TD height=17>10114184 </TD><TD>91-95 </TD><TD>427 </TD><TD>Truck Gen-5 </TD></TR><TR height=17><TD height=17>10134366 </TD><TD> </TD><TD>454 </TD><TD>4-Bolt Gen-5 Bowtie Tall deck </TD></TR><TR height=17><TD height=17>10185050 </TD><TD> </TD><TD>454 </TD><TD>4-Bolt Gen-5 Bowtie Short deck </TD></TR><TR height=17><TD height=17>10237297 </TD><TD>96-up </TD><TD>454 </TD><TD>4-Bolt Vortec 7400 Gen-6 </TD></TR><TR height=17><TD height=17>10237300 </TD><TD>96-up </TD><TD>502 </TD><TD>4-Bolt 4.466 bore Gen-6 </TD></TR><TR height=17><TD height=17>12550313 </TD><TD>91-95 </TD><TD>454 </TD><TD>4-Bolt Gen-5 </TD></TR><TR height=17><TD height=17>12556110 </TD><TD>01-up </TD><TD>496 </TD><TD>4-Bolt Vortec 8100 Gen-7 </TD></TR><TR height=17><TD height=17>14015445 </TD><TD>75-90 </TD><TD>454 </TD><TD>Car & Truck </TD></TR><TR height=17><TD height=17>14015543 </TD><TD>87-90 </TD><TD>454 </TD><TD>4-Bolt Gen-5 </TD></TR><TR height=17><TD height=17>14044807 </TD><TD> </TD><TD>454 </TD><TD>4-Bolt IV Bowtie Tall deck </TD></TR><TR height=17><TD height=17>14096859 </TD><TD> </TD><TD>502 </TD><TD>4-Bolt Gen-5 </TD></TR><TR height=17><TD height=17>24502504 </TD><TD> </TD><TD>454 </TD><TD>4-Bolt Gen-5 Bowtie Short deck </TD></TR><TR height=17><TD height=17>24502572 </TD><TD> </TD><TD> </TD><TD>4-Bolt DRCE-2 Olds "9.5"" deck" </TD></TR></TBODY></TABLE>
Engine number 2 sounds pretty plain jane, and I don't see the numbers from the 1st- might recheck it to see if its correct? Sounds like probably gonna be a "which is in best condition" contest though rather than trick factory setups.
engine #1 isnt special, but I dont even see #2 on the list. Need to recheck the casting # tomorrow. #2 has a flex plate and a pilot brng,and the bellhouseing dowels are missing. I could scrap them both and keep the small block that was in the car since 1958,but that would be too genaric.
