Customs Another bellybutton shoebox
Discussion in 'The Hokey Ass Message Board' started by flatout51, Aug 20, 2018.
  1. flatout51
    flatout51
    Geez... over 4 years since I've posted on this thread... built a 60 F100 4x4 and a Model A sedan but I'm finally back on the coupe. Little bit of a change of direction under the hood but should be a dang good combo. 390, C6, and will get an aftermarket OD unit on the C6. It actually fits way better than expected with the 4x4 pan. The 390 is completely rebuilt so is the C6. Plan is to finish the ch***is completely this winter so I can get back to the fun custom stuff. 20241016_121553.jpg 20241016_121553.jpg 20241016_121600.jpg 20241016_121611.jpg 20241016_121627.jpg
  2. flatout51
    flatout51
    The valve covers will be changed to an early 352 set. These are just for mock up to keep everything clean inside.
  3. Tim
    Tim
    from KCMO
    Love it. Slick looking custom with a big engine has always been a favorite combo
    brEad and flatout51 like this.
  4. tubman
    tubman
    I'd lost track of this over the intervening years. Good to see you;re back on it! Everything looks great so far.!:)
    flatout51 likes this.
  5. flatout51
    flatout51
    I worked last night and had to take my boys to school and hit the DMV for a new license but I got out in the shop and made some motor mounts and modified the trans crossmember. It's sitting on its own weight now. Just tacked for now till I pull everything to finish the firewall. They should hold the heavy FE. 20241022_131359.jpg 20241022_131408.jpg
    Tim, brEad and warhorseracing like this.
  6. flatout51
    flatout51
    I absolutely hate floor work and I made a ton for myself with the huge C6 and ultra low stance. I bit the bullet and started building the transmission tunnel. Pretty big but I left myself some extra room under the floor and the stock seat still fits so it's all looking good. 20241114_131112.jpg 20241114_132440.jpg
    brEad, sidewayzz69, bobss396 and 3 others like this.
  7. Tim
    Tim
    from KCMO
    Nice! The last shoebox I had was low enough that a good percentage of the driveshaft was above floor height. Gotta do what ya gotta do!
  8. flatout51
    flatout51
    Thanks man! Yeah this on the entire driveshaft will be above floor level. The FE sits pretty high and the C6 is huge. It will all work out in the end and should be a pretty solid car
    brEad, leon bee and Tim like this.
  9. Tim
    Tim
    from KCMO
    Killer can’t wait to see it cruising! Should be able to take those round abouts sideways!
  10. flatout51
    flatout51
    The transmission hump came out better than I expected. I'm really debating on making it bolt in so it's easily removable. Maybe with Rivnuts? I know welding it in will make the entire structure more rigid tho. 20241118_130606.jpg 20241118_130626.jpg
  11. Tim
    Tim
    from KCMO
    Rigid vs how likely are you to pull only the trans and not the motor and trans ever?
    Factoring where the seat lands and how you drive I would probably lean towards welding it in.
  12. flatout51
    flatout51
    Agreed. The trans crossmember drops out from the underside pretty easy so it won't be an issue if it all needs to be pulled. Hopefully it won't needs pulled once it's in!! Haha
    warhorseracing and Tim like this.
  13. flatout51
    flatout51
    Got the engine and trans pulled to finish weld the mounts and got the firewall patched around the transmission dipstick and 20241119_132126.jpg 20241119_132136.jpg 20241120_125046.jpg 20241120_125058.jpg trans hump mostly welded yesterday. Ran out of wire. Got up today and got some wire and another sheet of 18 gauge and built my notch cover. It will work as a nice shelf in the trunk too.
    brEad and Tim like this.
  14. Tim
    Tim
    from KCMO
  15. 53olds
    53olds
    Right on, this summer I had a 50 with a 390 fe and 4spd in it!
    Tim, flatout51 and brEad like this.
  16. flatout51
    flatout51
    Nice!! I bet that was a fun car!!
  17. 53olds
    53olds
    I didn't get to enjoy it too much because it needed alot. But the current owner is in love with it.
  18. flatout51
    flatout51
    I didn't get much done this week with the holiday but I did get my lower column mount figured out and in. The Merc column and wheel should work great and look even better. Self canceling turn signals are high on my list of must haves so this fits the bill. 20241130_164754.jpg
  19. flatout51
    flatout51
    Braved the cold and got quiet a bit done this week. Pedals are both done, firewall holes all filled and painted, transmission crossmember done and painted too. Ordered a few parts for next week. See what we can get done then. 20241204_132513.jpg 20241205_130337.jpg 20241205_130447.jpg
  20. flatout51
    flatout51
    The plan for the car is to finish the ch***is completely before moving back to the body. So for Christmas I got a stainless exhaust "kit" and I got started last week. It's 2.25 inch stainless and I'm running dual Flowmaster super 44s. Pretty straight forward and easy set up. Just cut and weld. Turning out better than i imagined. Everything is just tacked for now. Had ro order some more hangers and ill be able to finish the p***enger pipe then finish weld. 20250116_154800.jpg 20250116_154711.jpg 20250116_154717.jpg 20250115_132047.jpg 20250115_132030.jpg
    Edward Poff, warhorseracing and Tim like this.
  21. Tim
    Tim
    from KCMO
    Nice and tight, should help with keeping it attached in KC roads lol
  22. Rand Man
    Rand Man
    Great thread.
  23. hotdamn
    hotdamn
    So stoked to see that FE found a good home!!!
    also stoked to see you back on this thing!
    Thulsa Doom and flatout51 like this.
