Technical Another Dead Perch Thread
Discussion in 'The Hokey Ass Message Board' started by Johnny Gee, Dec 18, 2016.
  1. Jet96
    Jet96
    from WY
    "Semi rhetorical thought-blabbing"
    . ....must use that in future conversation....
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Break this down and it translates to say the left side is the controlling side of a panhard arm because it is stationary just like the steering box is stationary to the frame. Now look at it like this. What would happen if a panhard was mounted in the reverse ?
  3. Finished my avatar (31 Model A) in 2014, the cross steering (40 Ford) seemed to work OK, went around a sharp rt. curve with my foot in it, hit a bump and the car went 4' into the left lane, luckily no one coming. Made a dead perch for the right side (photo), and have never had that problem since, put 11,000 miles on it in 2 years, I notice no difference in the ride, I like the dead perch and it doesn't clutter up the front end, underneath. In the photo, the dead perch I made is on the left, after powder coat.
    AHotRod, Kan Kustom and Johnny Gee like this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Very nice. May I ask how you came up with the angle of the shackles before welding. Was it that you used the angle that it sat at while static on the car with the full weight of it on it ? I bring this up everyone because a store bought dead perch is "fixed" and the manufacture really has no idea what your shackle angle is. What Gram did here (if I'm correct about where Gram welded his shackle) is eliminate any preload on that one side of his spring. The side with the dead perch, very important. The whole purpose of this thread is not to say a dead perch is right. But rather get to understand it's dynamics and it's affect's when certain things are either not understood or not knowing even what to look for to find the problem.
    1927graham likes this.
  5. I put dead perch in loose, let the jack down so the heavy Buick engine settled in, drilled and pinned the perch where it positioned itself, removed and welded it up. I bought a factory perch and it was way off, I thought, how can they sell these things, most would not fit. The perch might not be the answer for everyone, but it sure was for me.
    Kan Kustom, Jet96 and Johnny Gee like this.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ 1927graham Thank you for that bit of factual information.
  7. AHotRod
    AHotRod
    I've been making and putting dead perches on the drivers side since the early '70's. They flat work and handle great.
    Kan Kustom, 1927graham and Johnny Gee like this.
  8. Jet96
    Jet96
    from WY
    1927graham- That's a damn nice looking piece!
  9. keywestjack
    keywestjack
    from Pittsburgh
    Ok guys then which is s it...left or right?
  10. seb fontana
    seb fontana
    from ct
    Right..
  11. joel
    joel
    What he said. I did a '40 with a '36 dropped axle and split bones. GM 525 box, panhard rod equal to drag link (within 1/2 in.) and parallel; panhard mounted to frame on the drivers side and to wishbone on the right. The car was solid as a rock even above triple digits.
    keywestjack likes this.
  12. Kan Kustom
    Kan Kustom
    Nothing like good old American ingenuity !
    1927graham and keywestjack like this.
  13. clem
    clem
    Right for left hand drive cars.
    Left for right hand drive cars.
  14. clem
    clem
    I can't help but wonder how much preloading/pretensioning the spring would have an effect on handling. - with out panhard rod or dead perch.
    By this I mean that the spring is fractionally shorter than what most do, and the shackles are at 30 degrees loaded.
    Which leads to another question, - should the spring be pre-tensioned ?
    Interested in any comments.
  15. Kan Kustom
    Kan Kustom
