Hot Rods Another deuce build thread but hopefully different
Discussion in 'The Hokey Ass Message Board' started by hb32, Mar 10, 2015.
  1. Well after a lot of consideration and the bucket load of $$$`s I would need to get it to an acceptable level, I won`t be pursuing the Banger in my 32 pickup after all. I am in the process of acquiring a rebuilt flattie to replace the banger so a slight turn off course. Selling off parts in the cl***ifieds to fund the new mill.
  2. falcongeorge
    falcongeorge
    from BC
    HOLY ****. That's a seismic shift in direction old buddy. Are you SURE about this? Honestly, if it were me, I probably would (I would probably skip right over the flatty and put a mid fifties 2x4 Packard V8 in it:rolleyes:), but you have gathered such good stuff up till now. Are you sure about this??
  3. Yeah I know George but the cost of getting the little banger up to snuff was far outweighing the green in my wallet
    Working on acquiring a 59A for the replacement.
  4. falcongeorge
    falcongeorge
    from BC
    well, straight up, it will probably be more usable with the flatty.
  5. falcongeorge
    falcongeorge
    from BC
    Ok, so since your going flatty anyway,channel it and get some ford solids WWW's and merc caps while your at it!:D
  6. No whitewalls or shiny paint on my ride :cool:
    I wanted the banger to be different but also wanted a flattie for the looks.
    Jeff34 likes this.
  7. falcongeorge
    falcongeorge
    from BC
    well, judging by the way that stuff is moving on the cl***ifieds, I'd say its too late to turn back now...:D
  8. Moving forward on the pickup, I have definitely shelved the banger and am having a C69A built to replace it.
    Meanwhile I will be looking for the parts required to convert from the banger to V8 as in rad, V8 gas pedal, intake and other pieces.
  9. No real movement to report but as things progress, things change. Sold off most of the banger parts to good homes.
    Removed the damper as well as the banger gas pedal. I am now looking for a V8 rad and gas pedal.
    Latest pics with the empty hole looking for a motor.
    kidcampbell71 likes this.
  10. 3wLarry
    3wLarry
    from Owasso, Ok
    if you look at Dennis Lacy's '32 pickup build thread, a 283 will bolt right in there...and cheap too ;)
  11. Yeah but Larry...
    3wLarry likes this.
  12. Dennis Lacy
    Dennis Lacy
    If you are planning on installing the handbrake linkage in the rear brakes those round grease baffles are going to be in direct interference with the link bars that cross horizontally from the front shoe to the lever attached to the rear shoe. That's exactly why the '39-'48 baffles have a flat across the top.
  13. Progress in parts gathering, but thats about it.
    I found an original V8 rad and it is out for a recore. Also have an original s**** pedal ***y to install as well as original V8 mounts once the motor shows up.
    Settled on an intake, block letter Edelbrock regular, as well as a pair of 97`s, pictured below on the kitchen table before the wife gets home and now looking for block letter heads. Plans are to run the gen up front with a fan on it but that may change depending on clearance issues.
    Undecided on decent original heads or new out of the box, for better all round quality.
  14. x77matt
    x77matt
    Love the build so far! Perfect Patina...
    Matt
  15. Picked up a second top loader trans a couple of weeks ago as my first had a bad cluster gear tooth. It has perfect gears in it with slight bearing wear where the first had new bearings. In the process of swapping bearings and just need to figure out how to remove the snap ring on the main shaft. Block is out of the machine shop and awaiting ***embly.
  16. I am not sure if I have given you this info before so I will err on the side of caution. It's hell to get old. Some of these hurtles you have already p***ed but I wanted to keep the list intact.
    The following changes need to be made when replacing a Model B with a V8 (21 stud, others will require a few more things):
    Of course engine, motor mounts
    Muffler and exhaust system before muffler (same after)
    Radiator
    Radiator support rods This one usually gets overlooked until the last minute.
    Engine steady rods
    Hubcaps
    Starter switch (if it is early B with pull starter, yours looks late based on the firewall so you are probably ok on this)
    Transmission (gears interchange but cases are different)
    Choke (B is a cable, V8 is a rod)
    Accelerator linkage
    Engine splash pans
    Gas line needs to be routed from right on Model B to left on V8
    The B will have a few extra holes in the firewall pad from mounting the 4 cyl engine snubber
    Need to add emblem to headlight bar
    Need to accept the fact that the serial number (VIN) is for a 4 cylinder
    Interesting to note the increase in value for the car is about the same as the cost of making the change
    Charlie Stephens
    kiwijeff likes this.
  17. I did see this several years ago Charlie and thanks for posting.
    I do have a few items checked off on your list above.
    No intention of fooling any one by p***ing it off as an original 32 and more trying to recreate a pre 50`s hotrod pickup, if there was such a thing.
    I am gathering mostly original parts, where possible, to look the part.
  18. IowaMercMan
    IowaMercMan
    Subscribed. Love this build!
  19. FOURTYDLX
    FOURTYDLX
    Will follow along.
  20. In celebration of St Patties day, builder sent me a pic of the block dressed in green.
    LOU WELLS and Jeff34 like this.
  21. falcongeorge
    falcongeorge
    from BC
    Is he still on schedule for delivery at the Coastal Swap?
  22. Bader2
    Bader2
    That's green? Looks blue to me.
  23. brady1929
    brady1929
    Get those old eyes checked Todd. Hehehe
  24. Yeah I am hoping George.
    Ordered everything I need to finish rebuilding the transmission this week, so I can bolt it on the back and get it between the rails.
    Took apart the shifter today and need to replace some springs , otherwise the rest is good. May need you to come over for some ***istance when I set it in the mounts. Still have a few items to source and have not decided on 6 or 12 volts. Selling the gen I have and looking for an original that I can bolt an original deuce fan that I was fortunate to find local
    Decided to stay with stock iron heads for now.
    Other then that, not much to say.
  25. Looks blue but original Ford green from the late 40's
    I was on the fence about having it painted as nothing will be as nice or shiny and am trying to keep it looking " barn find " for a lack of a better term.
  26. falcongeorge
    falcongeorge
    from BC
    Can do next week, sunny right now, so i am trying to get garage time in. I think theres one nice day next week, other than that, any time.
  27. Won't be until the motor is in the garage and the trans is bolted onto it.
  28. Bader2
    Bader2
    Tell me about it!
  29. One more piece of the puzzle is completed. Finished off the transmission overhaul this afternoon and not sure if the clutch arm is positioned right. Also need to find torques for the front and rear bearing retainers. May get my motor early as well and just might make deuce days in Victoria.
