Hot Rods Another Deuce Five Window Gets my Attention
Discussion in 'The Hokey Ass Message Board' started by ct1932ford, Nov 1, 2023.
  1. ct1932ford
    ct1932ford
    Finished the rear taillights and spreader bar and redid wiring. Car now has license plate light and I eliminated about six foot of unnecessary wire. I have found some weird stuff on this car. IMG_9292.jpeg IMG_9294.jpeg
    Stogy, clem, chryslerfan55 and 8 others like this.
  2. ct1932ford
    ct1932ford
    Took the grill shell and inert off the car today. The insert had some surface rust. When taking it apart I discovered that the insert was installed in the shell with sheet metal screws and then black rubber caulk was on the back to hold them in. I have never seen such lousy work.
    All finished sanding the insert and painting. Also cleaned and touched up the shell. Insert installed the way it should be. Ready to go back on tomorrow. IMG_9313.jpeg IMG_9314.jpeg IMG_9315.jpeg IMG_9316.jpeg
    Stogy, chryslerfan55, rod1 and 8 others like this.
  3. ct1932ford
    ct1932ford
    Finished the windshield wiper this morning. There was a motor just flopping around in header panel. Now mounted properly and wired. Chopped the arm and blade.
    Stogy, Tim, chryslerfan55 and 13 others like this.
  4. ct1932ford
    ct1932ford
    Finished going over the front end today. Spring, shackles, front brakes and wheel bearings all serviced. Front brakes actually looked great just needed some lube at friction points. IMG_9322.jpeg IMG_9325.jpeg
  5. ct1932ford
    ct1932ford
    I have been working on the coupe regularly. Making things better and pretty much have completed most of what I wanted.
    Installed the newly painted (Gloss Black) garnish moldings and dashboard. They came out great and interior looks so much better. IMG_9419.jpeg IMG_9421.jpeg IMG_9422.jpeg IMG_9423.jpeg
    Stogy, Paul B, Petejoe and 9 others like this.
  6. ct1932ford
    ct1932ford
    Just need to paint frame rails and should be ready to roll. Probably won't do that until early spring. Roads are a winter mess! :( IMG_9424.jpeg
    hook00pad, Stogy, Paul B and 11 others like this.
  7. ne'erdowell
    ne'erdowell
    NICE CAR! Seems like you do have a steady flow of beauties.
  8. ModelAMitch
    ModelAMitch
    Looks great!
    Whats that switch in between the p***enger side window and rear window? Just curious..
    Stogy and chryslerfan55 like this.
  9. flyn schlosser
    flyn schlosser
    from Elko,NV
    Awesome job...beautiful car...
    ct1932ford, Stogy and chryslerfan55 like this.
  10. Fogger
    Fogger
    Beautiful 5W and great attention to all the details. Beautiful interior and finish. Switch is for the dome light.
  11. Groovy
    Groovy
    Do you know how much of a chop was done to this one?
    Stogy and ct1932ford like this.
  12. Happydaze
    Happydaze
    Interior / dome light switch. Looks like a stock one.
    Terriffic car!
    Chris
    ct1932ford and Stogy like this.
  13. ct1932ford
    ct1932ford
    Interior dome light.
    Stogy and Just Gary like this.
  14. ct1932ford
    ct1932ford
    3"
  15. Tim
    Tim
    from KCMO
    Been a while since I’ve checked in on this one! Looks fantastic man
  16. ct1932ford
    ct1932ford
    Well finally got most of this project finished. Took it out today for the first time. Flathead runs strong and car is pretty quick.
    Still need to have frame rails painted .
    Only issue is one head bolt is weeping coolant. Will go after that this week. IMG_9638.jpeg IMG_9641.jpeg
    hook00pad, jnaki, Fordor Ron and 17 others like this.
  17. Petejoe
    Petejoe
    Just beautiful. black on black on black
    3windowlarry approved.
  18. ct1932ford
    ct1932ford
    Thanks, that's an honor.
    Stogy, pprather and Petejoe like this.
  19. HOTRODPRIMER
    HOTRODPRIMER
    Mark, This might be the best looking Deuce you have built, it's just got the look that can't be beat! HRP
    Stogy, clem and ct1932ford like this.
  20. AVater
    AVater
    Nice work Mark and great looking paint job there as well!
    Many happy smiles ahead!
  21. ct1932ford
    ct1932ford
    Could not buy a cowl vent screen since no vendors had one . So I made one! IMG_9528.jpeg IMG_9530.jpeg IMG_9532.jpeg IMG_9536.jpeg IMG_9535.jpeg
  22. ct1932ford
    ct1932ford
    Thanks Danny, I did not completely build this car although I pretty much have gone over most of it and not finished yet. Best to Brenda!
    Stogy likes this.
  23. TomT
    TomT
    It's one of the best looking 32 Ford I've have ever seen - fantastic job!
  24. Tim
    Tim
    from KCMO
    So good
  25. RockyMtnWay
    RockyMtnWay
    Great car and wonderful work as usual.
    Side note: It’s funny how we all gripe a little about previous owners work on these +80 year old cars, but the real benefit of these nits (as I call them) is that they make us go over every square inch of our “new to me” gems. A weird pride comes in finding/fixing all these little nits and it gives us something to do (especially through the winters) :):).
    If we are lucky, and if it’s hidden somewhere, we find the one scary **** job that could have caused a major incident out on the road. Even better if we do a thorough job and find nothing, but how often does that ever happen? :eek::eek:
  26. ct1932ford
    ct1932ford
    Never! Trust me.
    Stogy likes this.
  27. Stogy
    Stogy
    @ct1932ford high praise on making it your own this time around again...truly a stunning Hotrod...Night and day from page 1s revival. Truly a different period. You have really found that sweet spot after owning so many of them...still picking my jaw up off the floor...;)
    ct1932ford likes this.
  28. UNCLECHET
    UNCLECHET
    You are a magician! Both of these cars are spot on! Well done.
  29. hotrodA
    hotrodA
    When you think that your coupes can’t get any better, this one comes along!
    You keep raising the bar!
    WOW!
    Stogy, TomT, ct1932ford and 1 other person like this.
  30. ct1932ford
    ct1932ford
    Thanks!:cool:
    Stogy likes this.
