Technical another electric fuel pump question
Discussion in 'Traditional Hot Rods' started by dmdeaton, Jan 7, 2018.
  1. dmdeaton
    dmdeaton
    Done the search and read some, but cant find what I need. Build my banger with a Stromberg 97. Using stock cowl fuel tank in a 30 model A. Looking for fuel pump and regulator that will last a while.
  2. 55styleliner
    55styleliner
  3. I have used Carter Electric Fuel Pumps for about 40 years
    on my Race Cars & My 50 mercury
    Its a Rotary Vain type of Pump
    Just my 3.5 cents
    Live Learn & Die a Fool
    HemiDeuce and mad mikey like this.
  4. BamaMav
    BamaMav
    from Berry, AL
  5. Sheep Dip
    Sheep Dip
    from Central Ca
    dmdeaton likes this.
  6. orangeamcs
    orangeamcs
    I run the Carter pumps with the low pressure Holley regulator
    Sent from my SM-G930V using The H.A.M.B. mobile app
  7. 19Eddy30
    19Eddy30
    from VA
    Gravity feeding from Cowl tank to carburetor will be OK ,no electric fuel pump require
  8. dmdeaton
    dmdeaton
    I like the little Holley. Is it dependable?
  9. Sheep Dip
    Sheep Dip
    from Central Ca
    Well 11,000 mi. so far with no hiccups. I do run a relay even though it doesn't draw much amperage.
  10. mad mikey
    mad mikey
    Carter gets my vote. Use a quality regulator .;)
  11. SHARKO
    SHARKO
    My Carter lasted 15 years and expired 200 miles from home . I got a Holley on a Sunday in a little town. But my Olds has been rich for a long time-finally so stinky my wife won't ride. Upon Forum suggestions I went to check my regulator and it was gone?...maybe that Sunday? Anyway I'm going back to a mechanical pump with a kit ordered from Hal at Cl***ic Preservation Coalition and a freshening of my 3 Rochesters after 27 years. Aside from being lonely the problem with too much gas is rapid cylinder wear.
    Pat
