another F100 steering box question
Discussion in 'The Hokey Ass Message Board' started by Paul, Apr 6, 2009.
  1. Paul
    Paul
    Editor
    I tore my '53-'56 box apart and found the worm had a bite out of it,
    ordered a new worm,
    pressed it on and re***embled it
    it had a little play at the ends so I ordered a new pin and roller
    the stock pin was peened in place
    'used a drill to remove one of the peened ends
    and got the new pin and roller in all nice
    now how do I peen the new pin?
    it's quite hard ya know,
    heat?
    take it to a shop with a million ton press?
  2. Paul
    Paul
    Editor
    I think I'll take the pin back out,
    anneal the ends,
    put it back in
    then peen it..
  3. Bruce Lancaster
    Bruce Lancaster
    Give the middle of an end a good whack with a center punch...if the punch makes a mark, you can do the job. If punch can't get a bite....
    The pins used to hold driveshaft to pinion sleeve are hard to the point they are just barely punchable. I do them by savagely center punching at the center, then put in lots of punch marks all around that. Then I beat on the end for a while, medium grade blows with a medium sized hammer, and it slowly mushroomd from the steady rain of hammer blows.
  4. Paul
    Paul
    Editor
    thanks Bruce,
    I'll try that,
    heat is probably not a good idea here..
  5. mtflat
    mtflat
    I tacked mine in place with the welder - just enough that I could grind it off next rebuild and it's been holding up great for the past 9 years of daily driving.
  6. alchemy
    alchemy
    I tacked mine too. (But mine was an F-1, close enough?) If I remember right, there was nobody around to hold onto the thing so I could hammer with abandon.
  7. Paul
    Paul
    Editor
    well if I am going to put heat to it I'd rather it be the heat from a small spot weld then run the risk of losing the temper of the bearing surface by botched annealing..
  8. alchemy
    alchemy
    I kinda fingured that even if the tackwelds cracked, the blob on each end would keep the pin keyed in place and not allowed to turn.
  9. johnboy13
    johnboy13
  10. johnboy13
    johnboy13
    I'm just about to re***emble mine. Did you replace the bushings for the sector shaft? If so, have you honed them yet? That's a real treat!
