I have a one piece rear main block almost ready for the Bel Air. I need a manual trans flywheel for it. I found a flywheel on evilbay reasonably priced that fits 88-95 Chevy/GMC pickups. I believe my block is a 95-00 Gen 1 block; I can't remember the casting number anymore but I did check it once. Basically, were all the one piece rear main flywheels for late SBC blocks interchangable? Thanks in advance!
Pretty sure all of the '86 and newer stuff will interchange, but remeber there are two flywheel sizes out there. 14" and 12.75". I'm not sure what came stock in those trucks so make sure you know what size you're getting. - Matt
also don't forget to make sure that the back of the crank is for a manual trans and has the hole for the pilot bushing.
