Technical Another gas tank venting question
Discussion in 'Traditional Hot Rods' started by Ratspit, Mar 15, 2019.
  1. Ratspit
    Ratspit
    I picked up a stainless steel tank the other day on CL to build a gas tank for my 34 pickup. It holds almost 13 gallons which should be plenty of fuel. My plan is to build something similar to what Jimmy Shine did in his pickup. I have the filler flange and cap which came off a Lear Jet and the cap is not vented. It looks like the shine tank has 2 small br*** fitting between the cap flange and sending unit. The only thing I can find that looks like those are pneumatic breather vents my fuel tank.jpg shine tank 2.jpg 20190219_173823_resized.jpg 20190314_181843_resized.jpg . Has anyone seen a tank vented like this? Also looking for any other venting solutions that aren't obtrusive (and work).
  2. BamaMav
    BamaMav
    from Berry, AL
    What about drilling a hole in the cap where it would be hidden with the handle down?
  3. That’s all that’s needed.
  4. oldbanger71
    oldbanger71
    I would fit a breatherfitting on top of the tank. A hole under the handle would probably lead to spill petrol when sloshing arround in the tank, just my 2 cent.
    How about one of those stylish breather ? 10-0980_600x600-2xdtzuy0HPUA60N_600x600.jpg
    scotty t likes this.
  5. dirrty
    dirrty
    They make aircraft caps that are vented that will fit that flange. Look for something like Cessna or Piper. Jet fuel (like Lear Jet) use special venting systems built into the wing.
  6. sloppy jalopies
    sloppy jalopies
    great idea with that breather... the screen keeps the mud wasps from plugging it...
  7. Ratspit
    Ratspit
    Here is a picture of the bottom of my fuel cap. Hard to vent this one although I did find a few caps that had vents. Most of those had a smooth outer edge and didn't look as cool as the notched edge. As Dirty mentioned the vented caps were off a Cessna or Piper. I like the idea of the little breather fitting. The key is trying to figure out how to keep the gas from puking out of it and down the side of the tank. DSCF7754.jpg Screen Shot 2019-03-15 at 8.45.39 PM.png
  8. Blue One
    Blue One
    from Alberta
    The tank should have more than just a simple vent.
    It should have a rollover safety valve too.
    They have a check valve inside that stops the fuel from leaking out in a accident.
    mgtstumpy and 5window like this.
  9. sawbuck
    sawbuck
    from 06492 ct
    old banger do you have a link for that breather ? or where to buy one ?
  10. Ratspit
    Ratspit
    Here is a breather similar to the one oldbanger71 found. It is for a marine application. These are typically mounted on the hull of a boat away from the tank and any sloshing. breather.jpg
  11. Blue One
    Blue One
    from Alberta
    Another vent without a rollover valve.
    Not good.
  12. Ratspit
    Ratspit
    Screen Shot 2019-03-16 at 8.12.08 AM.png This one meets the roll over spec and looks small.
  13. Ratspit
    Ratspit
    Another vent that might work but lacks the roll over function is a Harley crankcase breather bolt. Screen Shot 2019-03-16 at 8.01.35 AM.png
  14. Blue One
    Blue One
    from Alberta
    Exactly what I posted above and used on my RPU tank.
    I also converted the hose barb over to hard line.
  15. Aaron D.
    Aaron D.
    You really should use a roll over vent valve. Just run a hose off of it to below your bed. It's a fuel tank, people expect to see fittings coming off of it.
  16. Ratspit
    Ratspit
    Blue,
    I like how you modified the vent. The hardline looks a lot better then rubber hose.
    Blue One likes this.
  17. oldbanger71
    oldbanger71
    Here's the link to the Vent i menshioned :
    https://www.offshore-yachtshop.de/s...ter/142274/tankentlueftung-rustfrigerade-16mm
    @ Blue, you are right about the roll-over function, i should have sayed that, but thought this was logical with tank like this.
    Anyhow i would use one of these with a internal roll-over-valve.
    My two cent.
    sawbuck likes this.
