Technical Another Holley 3310 Question
Discussion in 'Traditional Hot Rods' started by Wildman1, Sep 25, 2018.
  1. Wildman1
    Wildman1
    I have a broken spring on my 3310 - I have attached a photo with the part in question circled in red (the spring pictured is NOT broken like mine)
    That us the purpose of this ***embly?
    That is the name of this spring, and where can I get a replacement?
    Thanks in advance!
  2. squirrel
    That's the fast idle adjustment, the choke is connected to that cam, and the idle speed goes up as you close the choke. Which spring is broken? :) I see two in the circle
  3. Wildman1
    Wildman1
    The one at the end of the yellow arrow
  4. squirrel
    that's what I would have guessed...
    Are you using the choke?
  5. tdhug
    tdhug
    from kelso, wa
    give me your address and I will send you one. tom
    Sporty45 likes this.
  6. Wildman1
    Wildman1
    manual cable choke
  7. squirrel
    Take him up on his offer, you probably need that spring.
  8. Wildman1
    Wildman1
    Thanks Jim & Tom!
    Is the spring available new from Holley?
  9. Wildman1
    Wildman1
  10. squirrel
    Sporty45, Truck64 and egads like this.
  11. UNSHINED 2
    UNSHINED 2
    If you are industrious enough, springs can be made.....
    MMM1693 likes this.
  12. deathrowdave
    deathrowdave
    from NKy
    The purpose of that spring is to keep high idle adjustment screw near high cam in the chock linkage . I have a few of them laying around also if can not locate one from other members .
    Wildman1 and Sporty45 like this.
  13. Wildman1
    Wildman1
    I have been lucky enough to have help here identifying the spring, and an offer to send a spring to me (THANKS!) I was hoping to be able to buy a few & send a replacement back …. Holley seems to sell every part as a replacement - I just figured for a few bucks I could repay other's kindness
    Thanks Dave - if the other offer falls through I'll be in touch
  14. squirrel
    give Holley a call.
  15. Wildman1
    Wildman1
    Got it - Thanks Dave !
  16. Deuces
    Deuces
    Ok, so who here has a Holley 3-bbl carb for dirt cheap????.... :D;)
  17. deathrowdave
    deathrowdave
    from NKy
    Ha ha! Spend your money on a good carb ! 3 barrel wasn’t good when new , not to mention after years of abuse ! I have tinkered with many 3 Barrel and center squirters , not worth the effort .
