Another Molasses question...
Discussion in 'The Hokey Ass Message Board' started by Dexter The Dog, Sep 3, 2013.
  1. Dexter The Dog
    Dexter The Dog
    Hope this type of thing is not going to be considered too far off topic because I look to this forum as a great resource for all things build related...
    But anyway - A barrel full of molasses. What effect will antifreeze have on it or will it even freeze as it is? I've got 40 gallons of it behind the garage that's going to need some attention in a month or so on this note... And I don't think dollying it across the rec room floor is a good idea.
  2. 56sedandelivery
    56sedandelivery
    I don't think I would mix anything in with molasses other than water. Maybe try using an engine block heater, or one of those heaters used in Koi ponds so the fish don't get stuck under the ice. They also use heaters in livestock watering barrels, so a farm supply store might have what you need. Butch/56sedandelivery.
  3. ev88f
    ev88f
    Molasses won't freeze to begin with. If you've mixed it heavy with water then maybe think about a small stock tank heater
  4. Not only will a fish-tank heater keep it from freezing but it also speeds up the process of the rust removal. Of course, if you're not using the molasses anyway, does it matter if it freezes?
  5. If Dexter is anything like me just as it ices up nice and solid , thats when I would want to use it the most . Better run a heater bud !!
  6. I wouldn't eat any more of it if you put antifreeze in it....:eek:
  7. krooser
    krooser
    antifreeze ruins the taste...
  8. Dexter The Dog
    Dexter The Dog
    I plan on using this ugly bucket all winter long if I can but it would be my luck that something critical would be staring at me from inside a solid block of shellac until next April
  9. stimpy
    stimpy
    you could look into a drum warmer its a heating pad with springs on it that straps to the outside of the drum , we use it to heat thick chemicals , and they are safe for plastic barrels too .
  10. pitman
    pitman
    Fill a paper cup or ketchup 'cup' with it, and throw it in the freezer.
    Or when in the Maritimes, you're right, just wait a bit!
  11. 22george
    22george
    from ohio
    I've had a 9 parts water 1 part molasses mixture in a 500 gallon plastic tank for over 2 years including 2 winters with no problems. I didn't go out and check it for freezing during the winter, but my tank didn't overflow or split. I'm going to empty it this fall, not because of it freezing, but because it is old and stincks so bad.
  12. I had some hood sides in a 55 gallon drum of molasses for over a year with no problems, but no way would a 55 gallon drum ever freeze in Alabama so I never even thought about checking for that.
  13. Styleliner
    Styleliner
    If i were you i would chop the barrell 4 inches and find a pair of skirts for it.
  14. buickvalvenut
    buickvalvenut
    from Rialto
    you can sit on it thru out the whole winter,it it gets cold trow a blanket over it. and dont forget to change the diaper.
  15. teddyt
    teddyt
    from U.S.
    I have never used molases,........but I have used Metal Rescue,........amazing results!!
  16. buickvalvenut
    buickvalvenut
    from Rialto
    can you do a whole,( complete )engine for $17.95 using metal rescue? I did using molasses.
    a 5glln pale In a 55 glln plastic drum.it even lossens paint.no shit!
    I advise everybody to save there presidents,and try molasses.
  17. Roger Walling
    Roger Walling
    On the barrel of molasses freezing, when apple cider freezes, the very center contains alcohol.
    Try drilling out the center of the molasses and see what is there, you may be on to something great!
  18. Dexter The Dog
    Dexter The Dog
    I've had some ugly nights but waking up to those empty shot glasses would spell one nasty situation. Might bring up the iron levels in the blood though...
  19. oldolds
    oldolds
    I vote for putting a cup in the freezer. The process is slow enough at 70* below freezing I doubt it would remove much rust.
  20. Too expensive! I used distilled white vinegar $2.30 a gallon.
  21. 40FordGuy
    40FordGuy
    Would an engine block heater be too hot ?
    4TTRUK
  22. Roger Walling
    Roger Walling
    HONOLULU – Thousands of fish are expected to die in Honolulu waters after a leaky pipe caused 1,400 tons of molasses to ooze into the harbor and kill marine life, state officials said.
    The good news, all of the ships in the harbor no longer have rusty bottoms..
  23. krooser
    krooser
    Can you rig some sort of a t-stat?
  24. buickvalvenut
    buickvalvenut
    from Rialto
    Go to a hydroponics shop and buy a heater monitor used with a seedling heat mat.you set it at the setting (temp) you'd like and a sensor signals the unit when to shut of and turn on wich ever heat device you'd be using.
    Its made by hydrofarm and cost between $15/$20.
  25. krooser
    krooser
    Here's my molasses deal...
    I have several different chains and hooks to allow me to hang several parts in the barrel at one time.
    I cleaned a LOT of stuff last summer so I decided to empty the old solution and refill it this summer. I simply dumped it out at the end of my driveway and flushed it into the street with a lot of water. What didn't go in the street went into my no-brother-good-in-law's parking lot.
    I mix mine about 3-1...
