Hot Rods Another pinion angle question
Discussion in 'The Hokey Ass Message Board' started by Beets, Aug 24, 2022.
Tags:
  1. Beets
    Beets
    Looking down from the top the pinion to transmission is roughly 2 inches different. It's an Explorer 8.8 373 gears to a 4l80e. Is this going to harm anything? Or am I going to have to narrow the rear to center up. Just trying to get this right before I do anything else. Thanks
  2. squirrel
    As long as the engine/transmission is at a 90 degree angle to the rear end, the 2" offset of the driveshaft will be fine.
    Kevin Ardinger, jaracer and jimmy six like this.
  3. Beets
    Beets
    Alright I appreciate it. Some people say it's gotta be centered. But I've read more that it can be off. Just wanted to gather as much info as I can.
  4. seb fontana
    seb fontana
    from ct
    Just as a note a stock 1951 ford has a hair over 1" offset right from the factory.
  5. ebfabman
    ebfabman
  6. Beets
    Beets
    I appreciate the help with this. I just didn't want the driveshaft to be in a bind and cause a ton of vibration.
  7. Ned Ludd
    Ned Ludd
    True: provided the driveshaft isn't shorter than about 35"-40". With too short a driveshaft, the horizontal operating angle would eat up too much of the available vertical operating angle.
    warbird1, 2OLD2FAST and seabeecmc like this.
  8. Joe H
    Joe H
    It's no different then when looking from the side, as long as both angles equal each other and not greater then 3 degrees or so, but as mentioned above, you wouldn't want a whole lot of up and down angle to go along with the side to side angle.
    jaracer likes this.
  9. ekimneirbo
    ekimneirbo
    How does the current width of the rear end fit the car? Is it exactly the right width with the tires/wheels you plan to use? You may need to narrow it to fit the car properly. Other than that the rear offset is probably fine. The exception would be that if your car has an extremely short wheelbase, the angle of the offset will increase and could be a problem. Thats probably not the case here.
  10. 38Chevy454
    38Chevy454
    Short answer: no problem; ***uming your driveshaft is long enough and the vertical change is no excessive.
    Think of it like this, we'll use a 50 inch driveshaft length to help make math easier: From pure side view there is some vertical offset, let's say 2 inches down. The math says the angle is (inverse sin) 2/50 = 2.29 degrees in this orientation. From pure overhead view there is some horizontal offset, let's say 2 inches. Math says same 2.29 degrees in this orientation. The total offset of the driveshaft would be an angle of 45 degrees [2 inches down and 2 inches over] which makes total offset 2.83 inches. The math then says this total angle of operation is 3.24 degrees [(inverse sin) 2.83/50].
    3.24 degrees in my example is fine for U-joint life.
    Ned Ludd likes this.
  11. Don't listen to "some people", they are idiots
    Budget36 likes this.
  12. Kevin Ardinger
    Kevin Ardinger
    My 9 inch is like that. Doesn’t seem to be a problem.
