1952-59 Ford Another question...Drive line
Discussion in 'Off Topic Hot Rods & Customs' started by sobpunx, Jan 25, 2012.
  1. sobpunx
    sobpunx
    I don't have the car in front of me so I'm doing all the research I can do (it's at the in laws about 30 mins. away) will the stock drive line work with a aod? it origianly had a 3 speed (I doubt it's the right size but I gotta ask) and if it wont work is there another drive line that will or will I have to have mine shortened?
    thanks!
  2. flyboy89
    flyboy89
    from So. Cal.
    The AOD is going to be longer than the three speed. You will have to shorten the original drive shaft.
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    AOD's that came from a full size car are about 1 1/2" longer than a Mustang or Cougar AOD.I used a 1986 Crown Vic drive shaft in my '54 which has the correct front yoke, in my case I had to have it shortened 1 1/4" since I have it bolted up to the stock 4:10 '54 rear, I used a conversion U-joint to bolt up the rear NEAPCO 2-2091.My AOD sits right on the stock '54 crossmember and uses an ANCHOR 2253 mount available at Autozone,lots of info here:http://mustangsandmore.com/ubb/DanJonesC4AODswap.html also your donor AOD may need the shift lever modified depending on what shifter you use.
  4. sobpunx
    sobpunx
    Thanks for the info, I figured I would have to have it shorten. I just thought there might be some thing out there that would work, ohh well. I'm going to put a floor shifter in it so the linkage shouldent be a problem.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    Pick out the shifter before you install the AOD,some shifters like B&M have to have a lever kit installed in the valve body before you can hook up the shifter,it is a lot easier to do it out of the car.
  6. sobpunx
    sobpunx
    The aod is already in the car, I was thinking lokar. they seem ok any one have any problems with them?
  7. flyboy89
    flyboy89
    from So. Cal.
    Have one in our '62 F-100 with a 4R70W electronic O.D. No problems, pretty happy with it. Did have to change the selector shaft in the trans which necessitated dropping the pan.
