Technical Another Spongy Brake Pedal
Discussion in 'Traditional Hot Rods' started by JT1930, May 7, 2024.
  1. ronzmtrwrx
    ronzmtrwrx
    I'm going to ask what might be a dumb question, but here goes: why are your rear wheel cylinders on the bottom of your backing plates?
    SS327 and HemiDeuce like this.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    JT1930 likes this.
  3. SS327
    SS327
    Because he mounted the wheel cylinders upside down too.
  4. old hot rod
    old hot rod
  5. JT1930
    JT1930
    Backing plates are upside down first because model a rear end. I’m not going into detail of that. If you done know google.
    Also they are Lincoln backing plates. I would have clocked the backing plate to miss the spring perch but unlike the ford backing plates you can’t.
    Third. SS327 . The wheel cylinders are positioned correctly. Bleeder at the top. This has been done many times on here guys. I don’t know how some are shocked at what is being done.
  6. alchemy
    alchemy
    You did adjust the top (bottom on your rear brakes) locating stud to optimize the shoe’s up-down positioning, right?
  7. JT1930
    JT1930
    Yes. As Boling bros stated in their instructions.
    I got a couple new residual valves. Changing out the rear one first because I’m thinking since I had to adjust the pedal rod pushing on the mc a tad it is not holding the 10psi pressure to rears.
    I did a few up and downs on my road and it stops better than before. So we’ll see
