History Another Survivor Surfaces
Discussion in 'Traditional Hot Rods' started by Mark Jenny, Mar 8, 2019.
  1. 48fordnut
    48fordnut
    Thanks for sharing,HRM and later pics. Very Blessed.
    loudbang, Stogy and Mark Jenny like this.
  2. Mark Jenny
    Mark Jenny
    Blessed indeed!!...God loves old hot rodders!!
  3. Tim
    Tim
    from KCMO
  4. pumpman
    pumpman
    Amazing, I can't get over how clean it is. You are one lucky guy!
    Stogy, Mark Jenny and brad2v like this.
  5. 56sedandelivery
    56sedandelivery
    Be sure to use 265 intake gaskets, Fel Pro MS9200B; you can see how well the gaskets that were used were at risk of not sealing well (327 gaskets?). Also, remove the tin cover underneath the 2 X 4 intake manifold; these manifolds were thin and porous, especially in the heat crossover. They actually can burn through, and can cause all kinds of problems depending on how bad it gets (engine fire, oil usage, exhaust smoke, etc). Neat car and time capsule; why can't I find something like this, not that I can afford it now anyways (I have to help support our adult daughter)? I am Butch/56sedandelivery.
    loudbang and Stogy like this.
  6. 19Fordy
    19Fordy
    Just think, those were the days when people wrote letters.
    Stogy, Artiki, kidcampbell71 and 5 others like this.
  7. Mark Jenny
    Mark Jenny
    I bought a gasket set for a 265...hopefully it is correct...what is that shield under the carbs suppose to do?...Thanks for the info Butch..
    Stogy likes this.
  8. Mark Jenny
    Mark Jenny
    yep..and had to develop the pictures they took before they could send them in the mail to the magazine...nothing got done fast...but I think people were happier back then...or at least it seemed that way
    Stogy, scott27 and Moriarity like this.
  9. Mark Jenny
    Mark Jenny
    had to remove the top, and the headliner had let loose from the bows,so it had to come down to be repaired,which led to most of the interior coming out for a tune up...should be able to save the majority of the original interior...it also needs a new roof wood kit.. IMG_2136.JPG IMG_2137.JPG
  10. mgtstumpy
    mgtstumpy
    Wow, they're obviously still out there waiting to be found. Great score! Looks to be really solid and original.
    Mark Jenny and Stogy like this.
  11. RustyDogg
    RustyDogg
    Insanely cool! Good for you
  12. Mark Jenny
    Mark Jenny
    If anyone out there has a pair of older chrome rims that would fit the look of the sedan I'm looking to buy a set..15"x7 with chevy pattern..I need to match the fronts IMG_2132.JPG
    51box, Shadow Creek, slv63 and 3 others like this.
  13. Mark Jenny
    Mark Jenny
    Its in amazing shape for it's age!!
    Stogy likes this.
  14. Mark Jenny
    Mark Jenny
    Thanks!
    Stogy likes this.
  15. Mark Jenny
    Mark Jenny
    Master cylinder is completely froze up...my buddy identified it as a chevy master cylinder and pedals...will make an attempt at rebuilding this one...all the brake shoes are like new!...I'm sure I will have to rebuild all of the wheel cylinders.. IMG_2129.JPG
  16. Mark Jenny
    Mark Jenny
    here is a pick of the old kool steering wheel...all the garnish and dash are chrome, but pretty pitted up...but still so cool IMG_2133.JPG
    Stogy, kidcampbell71, Keepat and 8 others like this.
  17. Mark Jenny
    Mark Jenny
    Stogy, kidcampbell71, scott27 and 5 others like this.
  18. Mark Jenny
    Mark Jenny
    heads and block/pistons all in good shape...had to clean up one valve that was rusted on the stem...so we clened them all and replaced the seals... IMG_2128.JPG IMG_2130.JPG
  19. That's a CRAGAR Slot and Dot steering wheel. Totally bad *** and Cherry Red. I have a few of those as does @Moriarity
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    Oh man!! A Cragar steering wheel!!!!
    Stogy, kidcampbell71, dwollam and 2 others like this.
  21. chevyfordman
    chevyfordman
    That is super kool
  22. Mark Jenny
    Mark Jenny
    what year did those come out?
    Stogy likes this.
  23. Mark Jenny
    Mark Jenny
    I knew it was cool just by looking at it...did not know the maker though
    Stogy likes this.
  24. ^^^Late 50's made until '68-'69 ish. I'll have to dig out the catalog's to verify
  25. Mark Jenny
    Mark Jenny
    that makes perfect sense ...I think the car was finished in 59
    Stogy and dwollam like this.
  26. Mark Jenny
    Mark Jenny
    The interior is very plain Jane ...just straight black Naugahyde...I thought about changing it to white tuck n roll, but I just need to leave it as it was built I think...I don't want to start changing it
    Stogy, chriseakin, Woogeroo and 3 others like this.
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    Cragar steering wheels are rare... I have a red one on my corvette [​IMG]
  28. 30tudor
    30tudor
    Great story.
  29. 56sedandelivery
    56sedandelivery
    Master cylinder and pedals are from a 49-54 Chevrolet p***enger car, just so you know what to look for as far as rebuild/replacement parts.. The tin shield riveted to the underside of the intake manifold is to keep hot oil off the bottom; interesting, since they also cover the heat crossover from the heads, and I always wondered about that; keeping hot oil of of something that's there to get hot. Cast pistons are in the short block, and it looks like Power Pack heads. Solid or hydraulic cam? Has the fan been cut down? Maybe it's the angle or something, or there just was't room under the hood. If you're in need of a "better" shifter with a full length handle, I have a NOS Ansen for the old Muncie 318 transmission, same that's in your car. Ansen shifters were made by the same folks who made the floor shifters for almost all 50-70's GM cars. I also have a stock Corvette 3 speed shifter tower like yours, that your PO that has cut down, heated up, and bent, and also a flat stick Ansen shifter tower (same as the factory one but with a flat stick instead of a round one); one of those I'd probably send for shipping only. Really Neat Car! I am Butch/56sedandelivery.
    Stogy, Chris and scott27 like this.
  30. Jalopy Joker
    Jalopy Joker
    right place at the right time - what dreams are made of
    Stogy, Mark Jenny and GoJoMoJo like this.
