Projects Another T build
Discussion in 'The Hokey Ass Message Board' started by TrueBlue23, Jul 16, 2021.
  1. TrueBlue23
    TrueBlue23
    We finally have it back on the ground. Its been mine and my Dads covid project,,we were hoping to have it a little closer by now, but you know how that goes.
  2. Dave G in Gansevoort
    from Upstate NY
    Nice! Love the Caddy, what year and size?
    Stogy and loudbang like this.
  3. Bugguts
    Bugguts
    I like the start. Now tell us more!
    Stogy, loudbang and TrueBlue23 like this.
  4. TrueBlue23
    TrueBlue23
    Long story short, me and my dad started a T bucket build about 20 years ago. Due to time and money, we never finished it and sold off the ac***ulated parts. So when Covid hit, I decided me or him weren’t getting any younger and started getting pieces to the puzzle. It’s a frame and gl*** body from spirit cars. Wanted a clean steel body but couldn’t really find anything worth messing with close so we settled on an extended gl*** body with a door. Dads not in bad shape health wise, he’s 75 and still going, but this project has really changed him. I haven’t seen him this excited for anything in a long time.
    raven, Driver50x, GasserTodd and 12 others like this.
  5. TrueBlue23
    TrueBlue23
    It’s a 68 472…we rebuilt it back stock. But with 500+ ft lbs it should haul some ***
  6. Mr48chev
    Cool, even stock with the right gears that Cad will push that car way faster than you want to drive it.
    Keep those progress reports coming.
    Stogy, Deuces, alanp561 and 2 others like this.
  7. Atwater Mike
    Atwater Mike
    That's the tune I like... Ch***is 'Hospital-clean', total package: 'Bunny-Quick'!
    Stogy, Deuces, -Brent- and 2 others like this.
  8. loudbang
    Like the blue inserts. :)
    Stogy, Deuces, alanp561 and 1 other person like this.
  9. Dave G in Gansevoort
    from Upstate NY
    Keep the pictures coming!
    Stogy and Deuces like this.
  10. TrueBlue23
    TrueBlue23
    Got the motor dropped back into the frame this week. FB4CAACB-BB8B-4C7B-9E8C-B4BC96423F7A.jpeg F7885474-53A0-43F9-A5AE-D2DF9B71DDEB.jpeg 14BF1A9D-98FE-458B-B1B0-EAAC6B0041E7.jpeg 261DB14F-331A-44DD-ACE0-4A5010A41BE2.jpeg
  11. Rand Man
    Rand Man
    This world needs more T builds.
  12. I do like the simple and clean look to this T build.
    GasserTodd and TrueBlue23 like this.
  13. captainjunk#2
    captainjunk#2
    im liking the cadillac engine
  14. evintho
    evintho
    Bravo! I too, like the blue axle insert and the 472 Caddy couldn't be a better choice!!
    TrueBlue23 likes this.
  15. TrueBlue23
    TrueBlue23
    Thank you all. I know the late 60’s Cads are borderline when it comes to Hambers but I love the look of it, especially with the snorkel air cleaner and cl***ic Cadillac VC emblems make it look a little more period correct ‍♂️
    Stogy and RodStRace like this.
  16. TrueBlue23
    TrueBlue23
    Weld, grind, weld, grind, weld some more, grind some more ‍♂️ 87B1D46B-5485-488F-9667-B1F3D0369CA6.jpeg
    Nads, tommyd, Lil'Alb and 8 others like this.
  17. Dave G in Gansevoort
    from Upstate NY
    I can feel your pain! I'm in the same mode. Just keep telling yourself that you really like doing this stuff, because after all it's just steel, and you can cut weld and grind to cover up your mistakes/changes in design etc.
    Now if it were wood working, you'd have firewood...
  18. hardtimesainit
    hardtimesainit
    That T frame is really nice !
    You and Dad did good.
    Who is the engineer ?
    Could you tell me about the rear end?
    I love that you are building with your Dad, while he still can ….good on you.
    Stogy, catdad49 and loudbang like this.
  19. TrueBlue23
    TrueBlue23
    Thanks sir..frame is built by Spirit. And I ***ume I’d be the engineer . The old man just goes with the flow. Also the rearend is a Ford 8 in.
  20. Dave G in Gansevoort
    from Upstate NY
    While you're discussing details, could you tell us about the hairpins, in particular the plate thickness of the web gusset? I have that in my future and I was planning on 1/8 inch steel plate. I wasn't going to be as fancy as you did, but I really like the looks of yours. Another idea to plaigerize...
    Thanks
    alanp561 and catdad49 like this.
  21. catdad49
    catdad49
    Boy, Howdy! On my first T bucket test drive, the owner said, “Make sure you’re pointed in the Right direction Before you hit the gas”! The next thing you know, we are heading for a tree, and just like that, we are now testing the brakes. That statement will Definitely apply in your case. Happy building, Carp.
  22. alanp561
    alanp561
    I like that part about, "cover up your mistakes/changes in design". It's all the same thing, isn't it?;)
  23. 55willys
    55willys
    An 8" is a great choice. It weighs about 100 lbs less than a 9" and that equals less unsprung weight. On a light weight vehicle there is not enough weight to control a heavy rear end and it can lead to a harsh ride. Think about that old 1ton truck going over a speed bump. Another thing that helps is using a soft spring pack and good but not stiff shocks. I had a car with extremely stiff shocks and hit a railroad crossing in a curve at speed. The rear bounced up and kicked a couple feet sideways. Got it back under control after a couple more violent bounces.
  24. choptop40
    choptop40
    thats gonna be fast ..
  25. AmishMike
    AmishMike
    Love this build. Gathering parts for similar modified. Have owned number of 472 caddie, great torque engine, even ran one with nitrous. ***ume u using turbo 400 came with the engine? Later model overdrive would be nice but do not know what would bolt up & you not building this for long drives. What rear gear ratio? What size are your frame rails? Can hardly wait to hear final weight.
    Stogy, TrueBlue23 and loudbang like this.
  26. TrueBlue23
    TrueBlue23
    Thanks! yes, were running a 400 behind it. Its an 8 inch Ford out back with I think a 2:79:1. I have no idea how it'll do with the low end torque of the motor. Gear Rations aren't my speacialtyo_O
    I did get color on the belly today. And got started on the brakes last week. Hope to finish those up tomorrow.
    EDIT: The first pic of the belly is after first coat,,its not that dry lol
  27. Jacksmith
    Jacksmith
    from Aridzona
    Oh man, that's gonna be a fun lil' car! Nicely done.
    With that horsepower / weight ratio, it'll be like sitting in the pouch of a wrist rocket! Hopefully the slicks don't hook up and the frame can take the incredible torque from that 472...
    I had a 60-something Caddy (4,600 lbs.) with a 472 and it would boil those hides from a roll!
  28. AmishMike
    AmishMike
    That 2.73 rear is for hi-speed but big engine & light weight should still give lots of low end speed. Cir***ference of rear tire ( rollout ) will also effect the “grunt”. Frame rail size??
  29. TrueBlue23
    TrueBlue23
    It’s a 2x3 with 3/16 wall. Spirit frame.
    loudbang and AmishMike like this.
