another " what are these worth" thread
Discussion in 'The Hokey Ass Message Board' started by trbomax, Jan 30, 2013.
  1. trbomax
    trbomax
    NIB 427 bbc pistons.One set is +0.060 12.5/1, pin bores cut for ff retainers at factory,they are 50 grams heavier than stock so it is reccomended that the assembly be rebalanced when useing them. One set std. 11.5/1. Pins are included.
    I got these around 1970 when I was running 427bbc in the drag boat.
  2. probably 500-800 dollars a set if you find someone with a 427 that needs them.
