Technical Ansen BlowProof Bellhousing
Discussion in 'The Hokey Ass Message Board' started by Robert J. Palmer, Jan 15, 2015.
  1. Does anyone have an Ansen catalog?
    Ansen Part # 5004-T for Chevrolet V-8. Original application ?
    -Thank-You,
    -Robert J. Palmer
  2. saltracer219
    saltracer219
    I will look tonight while in my shop
  3. bowie
    bowie
    If saltracer219 can't find his, I will dig mine out tomorrow when I get to work.
  4. bobss396
    bobss396
    Catalog? I just have the bellhousings.
  5. saltracer219
    saltracer219
    I have 1964 Ansen catalog. The ****tershield listings do not carry any part numbers like yours. The numbers I have listed are, c5557 is 55-57 chev p***, c5862 is 58-62 p***, c6363 is 63 p*** and so on. I think maybe you are looking at a casting number not a part number. I don't know if Ansen stamped or cast the actual part numbers in the housings.
  6. squirrel
    show us a picture, we might be able to figure it out.
  7. bowie
    bowie
    My 1971 Ansen catalog lists: stamped steel type for Chevy as p/n's SHH7041,SHH7043,SHH7044. For the cast style,Chevy p/n's SHC-6670,SHC-6672,SHC-6673,SHC-6674 and SHC-6675. No mention of any 5004-T for any Ansen pieces.
  8. Danny G
    Danny G
    I have 2 for a sbc with the 55-57 rear mounts ,one the bottom cover is round the other the cover has a flat bottom. I wonder why they did that
  9. Check the diameter of the ****ter shields, I'll bet the one with the rounded inspection cover is smaller outside diameter. The option maybe would be strength, a rounded inspection cover wouldn't flex as much and maybe keep the pieces off the track better.
  10. Katuna
    Katuna
    from Clovis,Ca.
    I took the pics off my phone so I'm not certain but I believe that is the same number on mine. It fits a Tri-five Chevy. It has rear motor mounts, correct?
  11. squirrel
    No starter mounting holes, so it probably is for the blocks with starter holes in them...and it does not have the ears for mounting in a 55-57...so my guess is it's for most Chevy cars and vette from 58 till mid 60s when it was probably made.
  12. No mounting ears.(we knew it wasn't 55-57) Father could not remember went to block mount starter.
  13. Montana1
    Montana1
    Is it cast iron or what???
  14. No cast steel (I think) 41 lbs with bottom
  15. 56sedandelivery
    56sedandelivery
    It is for a block mounted starter engine, so 1962 and later; the 62 327 had a block mounted starter, the 283's had bellhousing mounted starters. By 63, all were block mounted except for trucks, some of those went into the 70's with bellhousing mounted starters. I am Butch/56sedandelivery.
