Ansen NHRA Bellhousing - question on mounts
Discussion in 'The Hokey Ass Message Board' started by tjet, May 25, 2013.
  1. tjet
    tjet
    I have an early Ansen NHRA bellhousing. The upper half has mounting pads for mounts (similar to the bell in the photo)
    Does anyone have a photo of these mounts? Is it on a frame crossmember? Thanks
  2. F&J
    F&J
    I never owned one, but it must be only one of two types. Either the 55-57 Chevy car mounts, or the 60s Chevy truck mounts. They differ by the bolting type at the bell.
    truck used one bolt and one pin I think. And I want to say the car was 2 bolts, but it's been decades since I worked on those.
  3. 325w
    325w
    Looks tri 5 ish to me also.
  4. tjet
    tjet
    Regarding the 55-57 mount setup, do you know they are on a cradle that connects to both frame rails, or are they on seperate/divided mounts?
  5. painterdude1
    painterdude1
    from michigan
    There is a mount that is on the frame at the cowl that they attach to on each side of the frame
  6. tjet
    tjet
    Are these the mount tabs?
    This is a 57 Belair frame (I think)
  7. painterdude1
    painterdude1
    from michigan
  8. Danny G
    Danny G
    That is a wedge belhousing not a ansen. My ansen ,the bottom is removable, The mounts bolt to the frame with 2 bolts and to the belhousing with 2 bolts. That wedge is more rare than a ansen.
  9. F&J
    F&J
    I barely remember that tri 5 side mount, but i was thinking it did not have a crossmember like the Chevy trucks did.
    I don't know if the cast angle of the pad on the car vs truck bell is the same or not. I vaguely recall it is not? But I know they use a different rubber mount.
    Look at your Aftermarket bell to see how many bolt holes in each pad
  10. tjet
    tjet
    Here's an ansen (just like mine)
    it has 2 holes in each pad. I want to add these mounts to my 59 pickup (crossmember was previously removed on my truck)
    Thanks for the photo. Now I need to find the mounts
