Folks Of Interest Anson Axles
Discussion in 'The Hokey Ass Message Board' started by Tetanus, Oct 29, 2016.
  1. Tetanus
    Tetanus
    I think I got stiffed. sent Greg Haynes $300 for a 46 axle outright sept 4 and waited about a month called him he said it was done just had to blast it.that was 3 weeks ago about. the last week and a half I have been trying to contact him and no answer.Now I see his web site is down. I got that feeling I got f*#ked!!!anyone know this guy that could get a hold of him??Maybe something happened to him??I just wanted a nice job and heard a lot of good things about him so I went with him. I don't mind waiting for good workmanship but now I cant even get a hold of him.
  2. falcongeorge
    falcongeorge
    from BC
    Toby Denham likes this.
  3. krylon32
    krylon32
    from Nebraska
    I've had Greg do lots of axles, can't imagine he'd screw someone?
  4. 5window
    5window
    And, yet, the website has expired.
  5. Tetanus
    Tetanus
    Me either just can't get a hold of him and his web page is down,does not return my messages.hope he's ok
    Sent from my LG-US780 using The H.A.M.B. mobile app
  6. akoutlaw
    akoutlaw
    Greg has done a few axels for me. Never had any issues at all. Always has been a really great guy to deal with. I don't think that he is the kind of guy to stiff anyone, at least not intentionally.
  7. 117harv
    117harv
    Even though he is banned for some reason, I think he's honest. I do have a question, $300 for a 46 axle?
  8. Tetanus
    Tetanus
    No core and shipping included
  9. Tetanus
    Tetanus
    He called all is good axle didn't p*** mag test so he's doing another.
    504640 and falcongeorge like this.
  10. lodaddyo
    lodaddyo
    I got ahold of greg thru instagram and showed him your post. He said he was calling you
  11. dirt t
    dirt t
    Thanks HAMB!!
  12. falcongeorge
    falcongeorge
    from BC
    I think it was a clash of personalities.
    need louvers ? likes this.
  13. falcongeorge
    falcongeorge
    from BC
    Which brings to mind a question, well, not really a question, but seems obvious. Since ford axles are forged, a ring test same as a crank should be a good quick field test.
    Atwater Mike and porkshop like this.
  14. Tetanus
    Tetanus
    I'm sure it was good but after heating an bending something happened.this is why I went with him because ok isn't good enough.I have heard nothing but good things about him that is why I went with him.just lost contact with him.would you trust your life with a ring test?there's not much room from the king pin to the perch hole on these so it's a lot of stress in a short area to bend a 4" drop.
  15. falcongeorge
    falcongeorge
    from BC
    Ok, I will explain this slowly. "Field test" is something you do when you are away from the shop, like at a swap meet, or buying something off Craigslist for instance. You cant just carry it over to the "magnafluxing" table, they don't really have those at swap meets. So you are looking at an axle at a swap, and you are thinking to yourself, "gee, I wonder if this thing is cracked", so you give it a rap with a hammer, if it DOESNT ring, you put it back down and walk away. If it does, then you can pick it up and take it home for further investigation.
    Get it?
  16. milwscruffy
    milwscruffy
    I'm glad you got a hold of him and all is good. That is what this thread is about and not a ring test in a swap meet. Good luck with your build.
  17. falcongeorge
    falcongeorge
    from BC
    are you guys ever ****ing thick. I give up.
    lewk, brad2v, 19Eddy30 and 9 others like this.
  18. john dioli
    john dioli
    Im hoping to get my axle back soon (real soon) greg does great work just wish it would be easier to get a hold of him. Ive found out he does answer texts quickly. Cant wait to see the axle no doubt it will be perfect
    John
  19. falcongeorge
    falcongeorge
    from BC
    Keep on bumping it to the top, every time you do, my post gets another "like"...;)Maybe that should tell you something...
    As far as that goes, magging isn't the best way to check an axle anyway, it will only show surface cracks.
    If you really feel that a ring test is inadequate before you pull the trigger on a used axle at a swap meet, you could always carry Zyglo penetrant and developer with you to swaps, (scruffy, you can google that so you will know what it is), but its messy and time consuming, and not something most guys have kicking around, and like magnafluxing, it will only detect surface cracks.
    For all your *****ing Scruffy, you haven't offered any other options for crack testing at a swap meet, you just seem to feel you can gain "points" by shooting down what I said by throwing buzzwords around. It almost seems like I have more background in non-destructive structural integrity testing methodology than you do.;)
  20. Texas Webb
    Texas Webb
  21. treb11
    treb11
    Mag particle WILL detect sub surface cracks. They disturb the magnetic field and hold the iron powder along their position.
    Sent from my SM-G550T using The H.A.M.B. mobile app
  22. falcongeorge
    falcongeorge
    from BC
    Neither of us are really being 100% accurate here. It can give an indication of cracks that are close to, but not penetrating the surface, it will not give a clear indication of the depth or extent of a sub-surface crack, and it will not indicate cracks that are deep in the piece. Direct current magnafluxing will penetrate deeper in a parts cross-section than AC. Neither process is accurate on parts that are really thick in cross-section
    Because an axle is not overly thick in cross-section, its probably a moot point as applied to an axle. If magnafluxing showed a crack on both sides of the cross-section, it would be safe to say the axle is junk.
    Since getting an axle magna-fluxed at a swap meet is not within the realm of possibility, this does nothing to negate the validity of p***ing on purchasing an axle that does not p*** a ring test.
    loudbang, Hankster32 and porkshop like this.
  23. Thick !
    dingggggg
    before you spend money or any time on it.
    I've not yet to see a broken Henry axle
    Atwater Mike and loudbang like this.
  24. Atwater Mike
    Atwater Mike
    er...whutevver makes yer ear ring....
    continentaljohn likes this.
  25. thirtytwo
    thirtytwo
    Soo ...if I bring up cast axles... Can we make this go a few more pages? ;-)
  26. Torana68
    Torana68
    from Australia
    perhaps I'm nuts but I have this in the shed and use it on axles (or any part that could kill me) , if it shows something I chuck the part OR take it somewhere for an x-ray if its worth that much. As for cast axles I wouldn't use one while forged are available.
    falcongeorge likes this.
  27. 5window
    5window
    Good to hear. Hope you get it soon. As for the drama, I bet this will be gone soon.
  28. john dioli
    john dioli
    I'm hoping to hear from Greg this week I need to get my truck back on road for a parade
    milwscruffy likes this.
  29. john dioli
    john dioli
    Well an update I think ive been patient but its been 8 frigen weeks on a 2 week turn around greg wont return calls or texts, Ive talked to people that said hes had there stuff done in 3 weeks in the past, so if anyone knows him personally maybe ask what the hell. I may understand if he fell ill or had personal issue but at least have common courtesy to let your clients know the situation, especially since there are cars that need to be back on the road. Just a little pissy cause im big on customer service. What say you guys
    John
  30. dirt t
    dirt t
